3-Point Hitch Help,,
   / Help,, #1
Jonny3
UK
Ferguson TE20
Hi,
I'm currently looking after my employers estate and using his Massey TE20 tractor to pull a trailer. The problem I have is that I cannot lower the tow bar to hook up the trailer. I can't remember how I was shown to lower it.
Mad I know but can anyone help??
Cheers. John :)
   / Help,, #2
:welcome:
From Alabama. Someone here should be able to help but it may take a few days being the holidays and all.
   / Help,, #3
When you are sitting on the tractor,look to right side, do you see a half moon looking thing with nob,slide that thing down that will drop your three point.It has been many years since i had mine but i think i have that right.If this doesnt fix your problem send pictures.
   / Help,,
:welcome:
Thank you! :thumbsup:
   / Help,,
Hi Ron.
Yep the half moon handle is there and when I slide it down the three point doesn't go down??
:smiley_aafz:
   / Help,, #9
I take a try and guess that you have a T-boom between linkage and top link with 2 struts down to drawbar? If tractor is not converted at one time then it is the original solution. On T-boom should be a button to be pressed or a lever to twist / lift depending on the style T-boom you have.
   / Help,,
Thank you for your suggestions. Yes it has a T-boom, which is in the middle of the 2 struts. I've pulled it and twisted it but nothing budges!
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
1963 Trail Mobil Tanker (A50514)
1963 Trail Mobil...
HYSTER 60FT WAREHOUSE FORKLIFT (A51242)
HYSTER 60FT...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
2025 Quality Steel Trailer (A50515)
2025 Quality Steel...
Wolverine Mini Skid Steer Auger Drive & Bit (A50515)
Wolverine Mini...
