3-Point Hitch Help,,
   / Help,, #11
On these tractors sits the hydraulic pump on the shaft for the the PTO. Therefore the PTO must be engaged and rotate to get oil pressure. Button on T-boom must be pressed simultaneously as one pushes the lever to 3 point hitch forward. On hitch there are three holes, the front one is hinging the middle is to lock the hook when no T-boom is in use and the latter is for the struts. check that there is nothing in the center hole. Remember that there is only a singel disc clutch on these so if it is pushed down then the hydraulic pump will not work
107" Bucket (A57148)
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2019 Ford F-450XL (A57148)
2019 Ford F-450XL...
SKID STEER ATTACHMENT PICKER (A58216)
SKID STEER...
2020 Steiner 450 Slope Mower (A57453)
2020 Steiner 450...
