HELP
/ HELP #1
ricdroc
I don't think any Yanmar tractor that has ever been imported to the states has ever had engine trouble. I have a 226d and threw a rod through the drivers side last week and have looked at ever site and supplier I can find on the web and nobody seems to have any engines. If anybody knows of a 3T75HA that is salvaged or if anybody knows if there is a direct replacement engine, ie 3T80 or 3T84 that would bolt right in I would appreciate a lead. I have a hole in the side about the size of a tennis ball. Thanks for any help.
/ HELP #2
I have am parting out a 226 with a bad crank. The block is good though.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
/ HELP
Definitely couldn't run by and see it. I am not sure if that is a direct replacement or not. Wish there was some kind of cross reference of engines to see what would be a direct bolt up from one engine to another. It would be nice to be able to pick up 8-10 hp if it became necessary to replace engine. I did see online a product call castaloy to fix cracks and holes in cast iron that is not a high temp fix. Is anybody familiar with this product or process?
/ HELP #5
Um i dont think a tennis ball size hole is not a crack or a small whole that some miricle goop called cataloy could fix? I think you just need to find you a good block and rebuild a replacement.
2022 EZ-GO ELITE...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2024 Polaris Sportsman 570 AWD ATV (A64557)
2024 Polaris...
2022 Timpte T/A Super Hopper Grain Trailer (A64194)
2022 Timpte T/A...
