Help!
/ Help! #1
canoetrpr
Veteran Member
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
Not quite sure how I managed to do this but my worst nightmare has come to pass.
I was working on getting my 150 hr service done today - basically oil and filter change. I've done two before - how hard can this be to screw up? Apparently not too hard!
I losen the bolts, drain the oil, go to tighten the bolts.
I decided that I really ought to start using my torque wrench to torque bolts instead of just winging it. I get the service manual out and it specifies the torque for the bolt (based on size and type). I come up with 50 ft lbs for the oil drain pan bolts.
I put the first one on, torque it, it clicks no problem.
Second one... not so easy, I put it on, tighten, tighten... I wonder why its not clicking... next thing I know, the tightness reduces and now I have a bolt that just spins in there once it is flush.
I'm not really sure what I did here. I'm not sure if it was cross threaded - pretty sure it wasn't, or if I over-tightend on a previous occasion and it just gave way now.
Boy this is a pain in the rear - particularly since I had my torque wrench out and was trying to do everything by the book.
I need some help trying to get this sorted out. I'm not sure if one should go about fixing this by re-tapping the bad hole to a slightly larger size and replacing with a larger bolt, or by just replacing the oil pan.
I noticed that the oil pan can come off. I'm trying to figure out exactly how. I figure that I will be better off working on this on a work table instead of under the tractor. There are about 12 bolts on it which I can take off easily enough. However, there is a Propeller Shaft that goes to the front axle that is under the oil pan and will prevent it from coming off. I am in the process of studying the service manual to figure out how to detach this so that I can get the oil pan off to work on it.
I sure hope that I am not the first guy to have run into this problem. Hoping some one here can help point me in the right direction.
If you have a guess as to what might have caused my mess do let me know as well as I am still scratching my head at this point.
/ Help! #2
Boy that REALLY sucks!:mad:
First, on the torque wrench thing-I believe what got you is the fact that the pan is thin, so the few threads that are there could not take the max torque.
I think you are also doing the right thing by removing the pan to work on it, and I would take tomorrow off and call your dealer Monday to check the price of a pan-after that figure is determined we can plan the next course of action.
/ Help! #3
I've not experienced the same thing but stripped many a bolt.
If it were me, I'd tap it in place, would just go up one size and I would imagine all would be good.
Shavings will want to drop out with gravity, I'd use a small magnet to clean up inside the hole when you are done.
I would try this prior to replacing the pan, just take a good look inside to be sure you'r not going to hit anything with the tap.
As this is only holding oil in, with no preasure or anything of that sort I'll bet you'll be no worse for wear.
Wonder if your torque setting was off?
I tend to only torque head bolts and lug nuts.
Good luck, could've been worse, could've lost oil while operating.
Joel
/ Help! #4
I hope you get this resolved easily. I too would likely try and swallow the bitter pill of a new pan, but I am one **** person when it comes to things like this.
I will say this as my own opinion; 50 foot-lbs. of torque on a thin-walled pan (as a general description) is a lot of torque. I do realize you were reading the manual but dang that is a lot of torque for that. Maybe I am wrong about that and just don't realize it.
I'll change all of my filters and fluids in the next day or so and the plugs will be snug-tight + a slight, firm turn.
Again, best of luck. It's just a small thing in the big picture.
/ Help! #5
Get the plug out and if you are lucky you striped the bolt and not the pan. If the pan is striped I would remove the pan and tap it to the next drain plug size. Probably what caused the problem is the where the drain plug threads into the pan it is only 1/4"thick. When you tried to torqued it to the torque of the bolt the nut wasnt strong enough.
Bill
/ Help! #6
Weld a nut over the hole with the same thread as the existing hole. You will need to drill out the old threads, so the drain plug doesn't try to start into those threads. Tig might be the best way, and I would consider dropping a hose emitting "inert" gas down the oil filler to prevent their being enough oxygen to allow a fire, in case the oil wanted to start burning. A water hose on the other end of the pan to reduce temp might also be an idea.
Removal of the pan makes the cleanup and prep for the weld a lot easier, and reduces the risk of fire.
Unless there are other problems with the pan, I wouldn't replace it, as it appears that with your luck, you would just strip out the new one.
David from jax
/ Help! #7
Another approach is to use a self tapping oil drain plug, which will cut new threads as it is screwed into the oil pan. The trick is to make sure the plug is started straight and work slowly. Also toss the nylon washer the plug comes with and replace it with a brass washer for a better seal.
/ Help! #8
It's a hassle to pull the pan, but you'll be better off doing so. You wouldn't want to chance damaging the engine with any shavings left over. Just a couple of years ago, I wiped a camshaft in an old car we have. I just replaced the cam, thinking that the filter would pick up all the metal. About 200 miles later, I spun a rod bearing. If I had just taken the time to pull it down and clean it, it may have not happened.
/ Help! #9
Obviously these guys are correct about pulling the pan, I've got a bad habbit of taking short cuts.
Good luck,
Agreed, in the scheme of things there are bigger problems to have, but does not help with the frustration of this one.
Joel
/ Help!
Will call dealer on Monday and price out a new pan.
Oddly enough tractorsmart does not seem to be able to tell me the price given a part number. I found a used one online for $72 - just by searching for the part number.
Now I've got to figure out how to get this dang propeller shaft off.
Guess you guys are right. I never thought about the fact that general settings on a torque chart ought not to apply to a oil pan that is quarter inch thick. I should have just been hand tightining an then adding a half a turn or a rule of thumb like that.
Live and learn I guess. Hopefully that is the last oil pan I buy.
/ Help!
Ok. I think I've got the propeller shaft all figured out. Man, I am happy that I got the workshop and parts manuals. I'm not particularly a handy guy and I don't plan on splitting my tractor anytime soon, but it is really nice to have these on hand.
/ Help! #12
Obviously you learned that 50 ft-lb is too much. Tin work bolts are 10-15 ft-lb. The drain bolt is sized for flow, not clamping strength. (Doh! obvious once thought about in the proper light.) Not meaning to beat you up (you've probably done a far better job than any of us could do.) But others may wonder why it happened.
There are many ways to solve the issue, new pan is one easy way. Welding a bolt into the back side of the pay may work. There is probably some junk on the back side to grind off. You can also tack in a piece of 1/4" steel. Just don't JB Weld it on and sell the machine! And certainly don't weld the drain plug on to the pan and sell the machine!!
In my youth, I've bought some like that and cursed the PO !!!
jb
/ Help! #13
Well.. everything aside... you're handy enough to tackle the job!! Some guys wouldv'e just called the dealer and loaded her on the trailer for a trip into their shop!
Think of all this "Priceless" knowledge you're accumulating!
Unfortunately, that's the way I've learned too many things... always peeing on the electric fence! :(
I just hate givin' up on fixin' things or tossing something in the scrap pile. I'd pull the pan and tap the hole with the next size up. You can go with the thread dimensions you want - no fine threads - good hefty ones!
Let us know how you come out.
AKfish
/ Help! #15
Thanks for sharing your problem although sorry to hear about it. I'm just about to do my 50 hr and this is a good tip to keep in mind (although I've lost my darned torque wrench someplace anyhow).
Seems reasonable to remove the pan, inspect and if OK re tap and use a new bolt. There really should not be anything wrong with it.
Let us know how it comes out.
Jim
/ Help!
It didn't look like pulling an oil pan should be a 3.5 hr job but man thats what it took me to to take that dang propeller shaft off so that I could take the oil pan off.
I spent the three hours cursing whoever came up with the idea of a 'spring pin' as there were three I had to tap out. The workshop manual is quite casual 'Tap out spring pin 1'. I didn't think that there existed a tool to snap out spring pins and man these were tight! The combination of a chisel that came with my air hammer, a hammer and a hex key FINALLY managed to do the trick.
3 spring pins later, the manual suggested something like I 'Slide coupling 2 to the rear and coupling 8 to the front'. The propeller shaft is hooked to the rear and front axle using two couplings and I remember reading in the manual that one ought to grease them when putting the shaft back on... well now I know why. I spent a fair amount of time and a lot of hammering to 'slide the couplings' :)
When it was finally done, I had a huge smile on my face, from ear to ear. I guess there is some pleasure in fixing things that you screwed up.
I now have the oil pan off and draining. It is a perfectly good pan so I believe that I will tap in larger size threads and pick up a couple larger bolts. I think that I will increase both to a larger size so that I don't have to take two different sized sockets under the tractor for my next oil change.
That better be the last time I over-tighten anything!
Thanks for all the moral support fellas.
/ Help!
Here is the latest development in my peeing on the fence story.
I went in to chat with the parts guys at my dealer's today. Was hoping they could find me a drain plug that was slightly larger - mine is a M12. That way I figured I could drill and tap the drain plug holes to the larger size and replace the drain plug bolt with a larger size.
They were unable to find one that was larger. They looked around various models and excavators etc. and found that all seemed to use the same M12 drain plug.
The suggested that I might want to try an auto parts store like NAPA and get an oversized self-tapping drain plug.
I want to do this right and I want to only do this once. My choices seem to be:
1. Oversized self tapping M12 drain plug at NAPA.
2. Been reading about Heli-coil and other thread repair kits (Timesert) that will restore me back to M12. The sound like they are REALLY expensive at Fastenal - about $90 or $100 - but still cheaper than a new oil pan.
3. Brand spanking new drain pan $219 CDN at the dealer.
I've heard some reports that the self-tapping drain plugs eventually leak - no clue whether or not this is true.
What do you guys think?
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
Yamaha 115hp 4-Stroke Outboard Boat Motor (A66738)
Yamaha 115hp...
Vortex Walk-Behind Paint Sprayer (A64553)
Vortex Walk-Behind...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2016 KEYSTONE 5th WHEEL (A67714)
2016 KEYSTONE 5th...
2023 CATERPILLAR 920 WHEEL LOADER (A65056)
2023 CATERPILLAR...
