Help with welding machine
/ Help with welding machine #11
I’ve had great luck with my Hobart 210. I bought mine a year before they came out with the 210MVP. Doesn’t bother me, I only ever run on 220v anyway.
I’ve burned a lot of wire, both solid and flux core with zero issues. I replaced the crap ground clamp it came with right out of the box just for peace of mind.
If I were buying a welder today, I’d get one of Everlast’s multi-process units. They look sweet, and the thought of a mig/tig/plasma in one unit is pretty awesome.
I’ll eventually get one anyway, even though I’ve got a decent mig and a great Hypertherm Powermax 45 plasma. Though, I may focus more on the stick/tig functions than the others.
Thanks for your input. I have almost bought a few units and am looking at the Everlast multi products pretty hard.
/ Help with welding machine #14
When I was looking into plasma cutters I was looking strongly at the Everlast unit as a past coworker bought one when they were cheaper than they are now and liked it and would have probably gone with the stand alone unit but when I was looking it was $600+ I think. All the reading I did on the cheaper import units said great things about the Everlast stand alone, but almost everyone said they wouldn't mix a plasma cutter into an all in one unit. Thinking about it it makes sense unless you can get all of your cutting done then switch to welding mode... I ended up getting a Ramsond plasma cutter from the Home Depot website for $400 I think, the thing is tiny and beats the heck out of an angle grinder and cutoff wheels! and was easier to get set up than getting my torch set out...
/ Help with welding machine #15
^ I adore my plasma, so many cool projects, cuts conductible metal like a knife, and doesn’t introduce nearly as much heat as a my torches do.
My brother was super anti-plasma cutter. Real old school kinda guy. He was trying to fabricate a new transmission cover plate out of 1/8” steel by cutting it with a torch.
I took some measurements, cut it, and drilled the holes in less time than he could believe. And it fit perfect with just a touch-up of the edge with a flap wheel to remove the dross. (Which basically just fell off)
I’ve made reinforcement plates for my M3 rear subframe, for my old Supra, my old Toyota Pickup, lots of projects both functional and art.
I am struggling between the Lincoln 210MP or the Everlast 211si. I am just trying to figure out which one will be easier for the beginner to operate and learn with. A plasma cutter will be my next tool.
/ Help with welding machine #17
Personally I like to have manual setups that don't take a minute to go through to tweak things... sure it's more custom but holy buttons batman! Lincoln makes nice stuff and I like the standard guide on the side cover and two dials on the front personally, that's one of the things that sold me on the Titanium Unlimited over the Vulcan Omnipro... sure it might know what's best but I'm not one to conform to the man... :)
It's kinda a tossup, I'm sure both would be awesome. I've been stick welding on and off for years, MIG welding at work here and there enough to dabble, and have one of the older blue 90A 110V flux welders from HFT and have done decent with that, the Unlimited is much nicer than the 90A even on flux core... man I need a bottle or two... and to get my shop going...
/ Help with welding machine #18
I've never used an Everlast but with the Lincoln you select the process (mig,tig,stick,flux core), push the botton, select the gas, push the button, select the wire diameter, rod, etc, push the botton, then select metal thickness you are welding on, push the button, and then weld away the machine has set the amps, wire speed, whatever. You can modify the settings if you wish by turning knobs but trust me it welds fine with the machine settings. I left our some other stuff such as pulse if using tig and if you are trying to go wrong by using electrode positive rather than electrode negative, etc. it will warn you.
/ Help with welding machine #19
I may have been thinking about the SquareWave tig with my comment about pulse, I don't think the 210MP has it.
/ Help with welding machine #20
I bought both a Lincoln 210 MP and a Square Wave 200 tig about a year and a half ago and really like both of them. This after using cheap Sears crackerbox and mig welders for thirty years or so. I really considered the Harbor Freight Vulcan equivalent machines at, then, about half the price but went with the red machines instead. There is a fellow on the welding wed forums who owns a welding business in Ventura, Ca. and he beta tested the HF Vulcan machines for a year before they were introduced on the market. He says they are good machines and are basically knock offs of the two Lincoln machines I bought.
+1 Good Call, Both very nice machines
2025 Kubota KX040-5 (A60462)
2025 Kubota...
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
HYSTER S60FT STRAIGHT MAST FOKLIFT (A59823)
HYSTER S60FT...
1010 (A61165)
1010 (A61165)
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
