Help with tractor hp/attachments
   / Help with tractor hp/attachments #11
The Westendorf site has good illustrations of some of the terms http://tinyurl.com/ap2bkg -A good way to learn what other terms mean is to search for them right here. Run a search for "breakout force" for instance.
   / Help with tractor hp/attachments #12
Bob,
I would be glad to go over the ASAE standards (universal rating system) of loader specifications that most loader companies follow.
It is how most companies standardize specs or take the measurments at the same PSI (hydraulic pressures) so you can compare lift capcities.
A third area that should also concern you is how the loader will fit or sit on the tractor. If it sits too far forward, you loose lift capacity. If it sits too high you can't see or you may not be able to "dig" with the loader.
If a company measures & publishes the lift capacity at the pivot point instead of the ASAE standard of 800mm out from the pivot point (bucket's front edge) you won't be able to lift what you thought you could.
When you talk about handling trees, adding a grapple, having stability... adding a ballast... there are many more items to consider to get you what you need to make your job easier.
Please call me at 877-MYLOADER and I'd be glad to give you pointers of what to look for in a quality built loader.
J. Ellingson
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Crane Truck (A60460)
2015 Kenworth T880...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
204158 (A57193)
204158 (A57193)
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
