Help with tig welding.
/ Help with tig welding. #11
Go to weldingweb.com and do a search for Syncrowave 250 settings. There is a thread there with a great cheat sheet.
/ Help with tig welding. #12
Mine's the newer version. They didn't change anything other than the cosmetics.
You should be able to go into a lift arc or SMAW and get an arc started if your remote (the pedal) isn't working.
/ Help with tig welding. #13
See if you have a remote setting it should be in the off setting.
/ Help with tig welding. #15
On TIG, AC is used for aluminum, DC for almost everything else.
With TIG you must have very clean metal before welding.
Freightliner Tender Truck - Adams Tender (A61307)
Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Kubota B2301 (A53317)
2016 FREIGHTLINER CASCADIA 125 6X4  T/A  SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
Giyi SGB20 QA Stump Bucket (A60463)
Giyi SGB20 QA...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
