help with stuct shifter
/ help with stuct shifter #1
realtinker
al was ms
1984 ford 1700
need help with my 84 ford 1700 tractor. my son in law was on it the other day and got the gear shifter stuck in gear. i dont know what gear and can not move the shifter anywhere. i not sure what i should do to free it up. i know when i drove it i had no trouble switching in and out gear but cant get anything except the gear it is in . i can shift from 1 , 2 , 3, and r which is the one on the right but the one on left wont budge.
/ help with stuct shifter #2
If you look at the area arround the shifter you will see 4 bolts. Each of these bolts has a spring and a ball under it. These are detents. They hold it in gear. Sontimes the balls get wore and become stuck.Remove one bolt at a time and check the shifter. When you find the one that frees the shifter remove the spring and ball with a magnet and inspect the ball for wear.
Bill
/ help with stuct shifter #3
Is it stuck while the tractor is shut off?
yes i tried rocking and no luck.
mine has two. i checked the on the right and took out two springs and it shifted out . thank you.
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2022 EZ-GO ELITE...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
