Help with sickle bar.
/ Help with sickle bar. #1
Birch Hill Farm
Kentucky
International 444
I recently purchased a old MF sickle bar and it is in great shape, but I am having one problem. The wooden bar that connects the flywheel to the blade keeps popping off at the blade. There is a ball and socket type joint that clamps down by flipping a spring loaded lever causing it to clamp onto the ball mounted to blade. The lever keeps flipping causing it to pop off before I can mow more then a few feet. Could the joint just be weak? Can I clamp it down some how or am I doing something else wrong here? Any help appreciated
Thanks Jon.
/ Help with sickle bar. #2
Is this a case for Duct Tape to keep the lever in place?:)
Wooden Bar = Pitman arm
It worked! It's mowing just fine now, guess I need to order a new part. So how strong is a wooden pitman arm? Why not use something steel.
/ Help with sickle bar. #6
Good show.:)
Wooden Pitman Arms have been in use for a long time. How strong they are I surely do not know.:)
/ Help with sickle bar. #7
Stay with wood....there's a reason it's made of wood.
You want it to snap if it gets under too much stress, in lieu of something else breaking that will cost a lot more to repair.....
VANTAGE 38' FRAMELESS ALUM DUMP TRAILER (A64278)
VANTAGE 38'...
JOHN DEERE 285 DISC MOWER (A64278)
JOHN DEERE 285...
2019 Ram 1500 Pickup Truck (A64556)
2019 Ram 1500...
S/A Tropic Trailer (A64557)
S/A Tropic Trailer...
Vortex Walk-Behind Paint Sprayer (A64553)
Vortex Walk-Behind...
2012 Ford Transit Connect Cargo Van (A64556)
2012 Ford Transit...
