Help with sickle bar.
/ Help with sickle bar. #1
Birch Hill Farm
Kentucky
International 444
I recently purchased a old MF sickle bar and it is in great shape, but I am having one problem. The wooden bar that connects the flywheel to the blade keeps popping off at the blade. There is a ball and socket type joint that clamps down by flipping a spring loaded lever causing it to clamp onto the ball mounted to blade. The lever keeps flipping causing it to pop off before I can mow more then a few feet. Could the joint just be weak? Can I clamp it down some how or am I doing something else wrong here? Any help appreciated
Thanks Jon.
/ Help with sickle bar. #2
Is this a case for Duct Tape to keep the lever in place?:)
Wooden Bar = Pitman arm
It worked! It's mowing just fine now, guess I need to order a new part. So how strong is a wooden pitman arm? Why not use something steel.
/ Help with sickle bar. #6
Good show.:)
Wooden Pitman Arms have been in use for a long time. How strong they are I surely do not know.:)
/ Help with sickle bar. #7
Stay with wood....there's a reason it's made of wood.
You want it to snap if it gets under too much stress, in lieu of something else breaking that will cost a lot more to repair.....
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2016 CATERPILLAR CP44B PADFOOT ROLLER (A65053)
2016 CATERPILLAR...
2009 8 Mil BTU Tri-Axle Hot Oil Trailer (A64194)
2009 8 Mil BTU...
2006 Ford F-250 Knapheide Service Truck with Liftgate (A64556)
2006 Ford F-250...
2011 FORD F-350 FLATBED DUMP TRUCK (A64278)
2011 FORD F-350...
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
