Help with sickle bar ID
/ Help with sickle bar ID #1
SwingOak
Central Wisconsin & in the Western UP, MI
'65 IH Cub Lo-Boy, '13 Kioti DK50SE HST, '20 Kioti RX7320
Hi Folks,
I've had this sickle bar attachment kicking around for years now, it came with my '65 IH Cub Lo-Boy, but I doubt it is for the cub. The mounting arrangement looks like it's more for a garden tractor - maybe a Cub Cadet? The bar is about 4' long.
Here are some pictures:
The drive pulley belt guard is moved out of the way, not bent:
This is the only number I can find on it - looks to me like just a casting number, and is that an "IH" below it?
Anyone have any idea what brand/model this is and what it attaches to?
Thanks!
I was looking at Haban Sickle-Mo's but I haven't seen any that look exactly like the one I have. Did IH make a sickle bar For the cadet? I know there are a couple of differnt models for the cub.
I'm debating if I should figure out how to mount it to my cub or my '78 Wheel Horse...
/ Help with sickle bar ID #4
I'm not familiar with the Cub Cadets, the only sickle mowers that I've seen on garden tractors have all been Haban. I suppose it's possible that Haban made one specifically for the CC.
Either way, these small frame sickle bars seem to be rare, so I started tearing it down tonight to rebuild it. I have my work cut out for me, this thing has been sitting outside for about 30 years. The only thing that will need to be replaced is the pivot bar for the blade angle, which was so badly rusted I had to cut it out with a torch and drill the ends out. Everything else came apart pretty easily. I'll have to replace all the bearings, so I have my fingers crossed they are standard and not OEM custom sizes!
Got most of the bearings out tonight, looks like they are all the same - Torrington J1210's, which fortunately seems to be a fairly common needle bearing. Looks like all the rod-ends are standard sizes too, as are the idler pulleys. That's encouraging!
OK finally figured it out - it's not a Haban, it's a Simplicity. Aptly named, the construction is not all that complicated. I found the manual for it online, and it looks like some parts are still available for it. But just for fun I'm in the process of modeling all the parts in Autodesk Inventor as I get them cleaned up and the paint removed.
Got the bearings, about $25 for all of them, and another $20 for rod ends. Started cleaning all the parts and stripping the paint off. I have a abrasive blasting cabinet so it goes pretty quick. Once I get the paint cleaned off, I can precisely measure and reverse engineer the part to create a 3D model. This way, if down the road something breaks I can make a new part if a replacement is not available.
Here's what I've modeled so far - the rocker arm, pitman arm assembly, and connecting rod assembly:
As you can see, I haven't painted the parts in Inventor yet either! ;)
I'm working on modeling the hinge now - cast parts are always tricky, and it's large enough and oddly shaped so it's difficult to measure. So once I model the actual part I can design a weldment as a replacement if it is ever necessary.
I've been painting the parts with Valspar Cub Cad yellow because I have a few rattle cans on the shelf, and just found out Tractor Supply isn't selling the Valspar paint any more. I'm going to check a hardware store nearby that might carry it. Seems like just about everything at TSC is made in China, and most of it is cheap junk too. I am increasingly unhappy with TSC, but that's another topic...
