Help with rotary cutter gearbox
/ Help with rotary cutter gearbox #1
Nate07
Germantown, ohio
None
I just bought an older ford rotary cutter. It is missing the top half of the gearbox and the pto shaft(I bought the thing for $60). The best I can tell the model number on the tag of the whole thing is 22-151. I’m having trouble finding the correct gearbox for it. The output shaft is 10 spline. All I am finding is 6,12,15 spline with bolt on blade. My blades are on the splined shaft with a shear bolt and no threads for a nut. I’ve not dealt with any bush hogs before. Just recently bought a new place with 4.5 overgrown acres I’m trying to clean up.
/ Help with rotary cutter gearbox #2
Hello Nate,
Welcome to the forum!
I have purchased used and new gearboxes and made the mount to fit them, while using the stump jumper from the old one. I have also purchased rusted out brushhogs that still had good gearboxes and stump jumpers (and blades), and put them on a completely different style bush hog.
A lot depends on your fabrication skills, when it comes to "making things fit".
Good luck,
David from jax
/ Help with rotary cutter gearbox #3
This hog sounds like a good project for someone with some fab capabilities, but it might not be a good first option for someone without. What tractor are you running this on? Might do well to look at other second-hand options, ready to run.
I’m a machinist/tool and die maker by trade, I know I can make something work I’m just trying to find the quickest option. My garage doesn’t have electric in it yet so I have limited abilities at the moment.
/ Help with rotary cutter gearbox #5
Cool. You run into all types, here.
Got any photos, so it's easier to follow what you're describing?
I suspect you're going to get more recommendations on gearbox replacement, unless there's any easy parts channel for that old Ford gearbox. And while I've never particularly followed Ford, I honestly didn't even know they made their own brush hogs. Are you sure it's not a re-badged Woods or other brand? That would really help with finding parts diagrams, etc.
Many will just find another rusted out deck with driveshaft and a good gearbox, and make the mod's required to their deck to transplant that other gearbox onto it.
I’ll take some pictures tonight and post them. I’m pretty sure I’ll end up replacing the gearbox, I’m just trying to reuse the blade mount and haven’t found one with the correct spline
/ Help with rotary cutter gearbox #7
Yeah, I'd assume replacing the blade/jumper assembly with whatever comes on the replacement gearbox. Especially if you go with something super common (eg. Woods or King Kutter), then blade availability becomes no problem.
So the spacing between blade hub is 16.5 and the blades measure 20.5 tip to hole
/ Help with rotary cutter gearbox #11
Not having electricity in the shop might be an issue! Maybe a cord from the house?
First off, as I see the pictures, this would not have been the brush cutter that I would have picked in order to do a 4.5 acre overgrown lot that I just purchased and wanted to clean up! There are way too many hidden obstacles in newly purchased lots that are unfamiliar to the new owner, and finding some of them with a cutter bar like you are trying to use is probably the reason the gearbox is missing parts. The splined fitting welded to a cross bar that holds the blades has no provision for things like hidden rocks, old engine blocks, well casings, (do I need to continue or do you get the picture?) The flat side tends to hit the hidden object and stop the swinging blades and something in between the engine and the blades has to give. Slip clutches, shear pins are typically the weak link, but old gears can only take so much before they give way.
Since you are replacing the gearbox, I would seriously consider looking for a rusted out deck with a gearbox and stump-jumper still intact, hopefully with blades that will fit your deck. Blade length can be adjusted a little, but usually not enough to go from a six footer to a five footer, etc, so look for rusted out decks in the size range you currently have.
I actually purchased a trailer load of rusted out brush hogs from a guy 90 miles away and hauled them home. The remains of that load are still piled up out back, and if memory serves me, there was even a blue one (as opposed to all rusty colored ones) in that bunch! However, getting it dug out to just look at it, and realizing the cost of shipment to the midwest, doesn't make it feasible, even at the heavily discounted price I purchased all of them at!
Good luck with this project,
David from jax
GIYI D680 - 56" HYD PILE HAMMER (A60430)
GIYI D680 - 56"...
Kivel Quick Hitch Skid Steer Attachment (A59228)
Kivel Quick Hitch...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
2019 Ford F-550 4x4 ETC37IH 37ft Insulated Bucket Truck (A59230)
2019 Ford F-550...
(125) PALLET OF UNUSED SAFETY CONES (A60432)
(125) PALLET OF...
2012 Ford Transit Connect Cargo Van (A59230)
2012 Ford Transit...
