help with replacing fan belt on Kubota B7100 with loader atta
   / help with replacing fan belt on Kubota B7100 with loader atta #12
Well I understand it is wonderful. What for? Why use one? What was its' purpose compared to a plain old shaft?
Oliver did it simply because on most tractros, removing the trans for work entails a split. With an Oliver, there is no split unless it's a clutch job.
   / help with replacing fan belt on Kubota B7100 with loader atta #13
This is what you are looking at. The master link is circled in red. Use a small screwdriver to slide the keeper back then you can start taking the link apart. Once the front of the link is off the rest will slide out the back side. Once you start it will make since.
Sorry for the rudeness of the previous poster. He forgets some people have never seen or done some things.
   / help with replacing fan belt on Kubota B7100 with loader atta #14
I see. The split link is the same design as on a bicycle chain. That's how the chain comes apart.
   / help with replacing fan belt on Kubota B7100 with loader atta #15
Yes but you can take the shaft out without moving engine or pump.
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2017 Ford F-250 Reading Service Truck (A55852)
2017 Ford F-250...
2013 Ford Edge (A54815)
2013 Ford Edge...
UNUSED FUTURE CAT 305 24" EXCAVATOR BUCKET (A57193)
UNUSED FUTURE CAT...
2016 Freightliner 114SD T/A 4,000 Gallon Water Truck (A53422)
2016 Freightliner...
2014 Ford Explorer AWD SUV (A55853)
2014 Ford Explorer...
