help with replacing fan belt on Kubota B7100 with loader atta
   / help with replacing fan belt on Kubota B7100 with loader atta #12
Well I understand it is wonderful. What for? Why use one? What was its' purpose compared to a plain old shaft?
Oliver did it simply because on most tractros, removing the trans for work entails a split. With an Oliver, there is no split unless it's a clutch job.
   / help with replacing fan belt on Kubota B7100 with loader atta #13
This is what you are looking at. The master link is circled in red. Use a small screwdriver to slide the keeper back then you can start taking the link apart. Once the front of the link is off the rest will slide out the back side. Once you start it will make since.
Sorry for the rudeness of the previous poster. He forgets some people have never seen or done some things.
   / help with replacing fan belt on Kubota B7100 with loader atta #14
I see. The split link is the same design as on a bicycle chain. That's how the chain comes apart.
   / help with replacing fan belt on Kubota B7100 with loader atta #15
Yes but you can take the shaft out without moving engine or pump.
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 40in...
2500 GALLON POLY STORAGE TANK (A57192)
2500 GALLON POLY...
2013 Ram 1500 Crew Cab Pickup Truck (A55852)
2013 Ram 1500 Crew...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
