Help with glow plugs
/ Help with glow plugs #1
decableguy2000
Bronze Member
Help me figure out if my glow plugs are going bad. I have a Farmtrac 300 DTC with a Mitsubishi S4L 1.5L engine. Hard starting when temps drop to around freezing. The book says the standard is .55 ohms. mine are reading .7-1.7 ohms. Should I replace them
Also need a cross reference for the glow plug to Mitsubishi #32a6603100, markings on the plug JA31M 10.5v h6b5
/ Help with glow plugs #2
Better to find a way to measure current flow through each injector when energized . Glow plugs or not , plug the block heater in to pre-warm the engine .
Portable Air Compressor w/Honda Motor (A64119)
Portable Air...
iDrive TDS-2010H...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
Schulte SBW800 Rock Windrower (A63118)
Schulte SBW800...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
24in. Terex Excavator Bucket with Teeth (A64194)
24in. Terex...
