Help with frustration first time using B2620
   / Help with frustration first time using B2620 #1
Tcfake613
Bronze Member
Elizabethtown, PA
Kubota B2620
Ok folks. Two issues today first time mowing. Hopefully this is something I'm doing wrong and maybe you guys can give me a hint. Brand new B2620 with 60"MMM and FEL. Loader is off for mowing today. No problems with that.
1. Sometimes tractor will not start. Turns over fine... Spits a little diesel smoke and dies. I try six or seven times and it eventually fires. Let glo plug heat for about 5 sec each time.
2. Mower deck keeps dropping on it's own. Set it at 3 and one dot... Mowing along and bouncing around a bit... My yard is not that rough... Deck dial drops to about 2 1/2.
Any ideas? Can't even finish mowing right now due to frustration.
Thanks in advance.
   / Help with frustration first time using B2620 #2
It's brand new? Call the dealer!
I suspect some safety switch is the cause for shutting the engine down.
I'm sure a Kubota owner will be along shortly, but you might post this in the owning operating sub forum instead of buying/pricing.
   / Help with frustration first time using B2620 #3
It looks like you talked to Les this morning, did you get this resolved? That is not normal.
Yes I did.. As well as Andy. They are coming out this week to take care of it. Great response and it is much appreciated!!
Thanks for the follow up!
   / Help with frustration first time using B2620 #5
How do you like the mowing quality (quality of cut) with your new tractor. Minus the dropping deck problem of course. :eek:
I'm very interested in the same tractor and curious how well it mows. That will be it's primary job at my place. :thumbsup:
That's the surprising thing. I assumed the cut would not be as good as my JDX520, however, I think it is actually better. The JD sometimes left uncut lines when turning tightly. With this tractor I get none of that. My guess is that my radius is not quite as tight therefore the blades are tracking more consistently and not causing the uncut lines.
I mowed yesterday and the grass was very long. Had the deck set at around three inches. The dispersement of the grass was much better than with the JD. It seemed to spread clippings very evenly, whereas the JD tended to throw the grass in a solid thick line.
The evenness of the cut is outstanding from what I can see when mowing on a straight line. Some of my yard is a little rough and this tractor is much smoother so I think the deck bounces less giving a more even cut. Being a new tractor, the blades are very sharp also. Although I did regularly sharpen the blades on my JD.
As long as I can get the deck height adjustment fixed, I'll be happy!
PS: Make sure your deck is properly level for best results!
   / Help with frustration first time using B2620 #7
Thank you so much for your reply! Sounds like it's a great mowing machine!!! Okay now I really want one! Lol!
I'm trying to decide between a B2620 and a BX2360. Price is a big issue for me. I have a L3830 so the BX maybe big enough. But I like the big tires on the B! :laughing:
   / Help with frustration first time using B2620 #8
I have a brand new B2320 with the 60"mmm and also love the cut.
   / Help with frustration first time using B2620 #9
Dealer prep on the new machine?
   / Help with frustration first time using B2620 #10
I noticed from your pictures that your mower deck is one of the earliier ones since it has the regular anti-scalp wheels instead of the wider, and less adjustable rollers that Kubota is using now. I think I like your set up better than the new one, but that is perhaps why the mower slipped through the tech bulletin upgrade. Your dealer should have the bulletin.
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
UNUSED FUTURE FT380 STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2003 Big Tex 10PI...
