Help with broken Sears axle?
/ Help with broken Sears axle? #1
The Haymaker
Benton, Maine
2008 T2220
Hi all, friend of mine came to me with a broken axle on this unit wondering if I could weld it. A replacement part would be a much more viable option, but he couldn't find a parts source used or new. Can anyone point us in the right direction?
/ Help with broken Sears axle? #3
Should be able to order it directly from Sears based on the Serial Number of the machine.
Otherwise, there are dozens of AYP dealers online. I would be willing to bet, you will have to buy the entire transaxle assembly though....
Yeah, unfortunately that's kinda what I was thinking on the whole unit deal. I'm not sure why he hasn't tried new. He may have said, but I was dodging traffic with a semi on I87 at the time.
/ Help with broken Sears axle? #5
Depending on where it broke, you could weld a sleeve over the break.
Yeah, that was my original thought and why he asked me about it. By the sounds of it, there is only 1/2" between the break and housing. It'd be tough.
/ Help with broken Sears axle? #7
You may be able to read the tag on the transmission to get the model number for the tranny, then look up parts for the tranny. Most likely it is a Hydrogear, and individual parts should be available through any hydrogear dealer, which would include Mtd, Poulan, Husqvarna dealers.
/ Help with broken Sears axle? #8
My local repair shop has what I call a lawnmower graveyard to pull parts from. Just an idea.
2018 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2018 SolarTech...
Case IH 1020 15' Grain Platform (A66408)
Case IH 1020 15'...
1989 Cheetah Chassis Corp 40ft. 36 Ton T/A Container Trailer (A64556)
1989 Cheetah...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
2023 Bobcat T595 Compact Track Loader Skid Steer (A64553)
2023 Bobcat T595...
40' High cube 6 door Single use Shipping Container (A64194)
40' High cube 6...
