Help with annoying problem
   / Help with annoying problem #1
TPONZ
McCormick xtx 145 Xtra Speed
Hi, My 2011 McCormick XTX 145 is running just fine from the moment i start it until i have to exit the cab and on my return find the transmission
has gone into neutral, the only way i can get going again is to shut down the engine and then restart the engine at which time my
gears are back and i can set off again.
Anyone have any ideas as to what might be wrong and how i can rectify ?
   / Help with annoying problem #2
seville009
Veteran Member
Not familiar with your machine, but generally its probably something loose in the shifter - retaining pin or something like that.
   / Help with annoying problem #3
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Is it a safety thing, leaving the cab locks out the trans?
Has it always done this or is it a new problem?
   / Help with annoying problem #4
oosik
Super Star Member
AMBER, WA
2009 Kubota M6040
AH - perhaps a new twist to the "leave the seat" safety system.
   / Help with annoying problem #5
Hay Dude
Super Star Member
The Corrupt Rust Belt
Case-IH MX-270, Massey Ferguson 7495, Challenger MT535B, Kubota F3680 & ZD331 Ram 5500 Cummins 4x4, IH 7500 4x4, Kaufman 35’ tandem 38,500lb trailer
What kind of reverser do you have F-N-R or same but with “P” (park)?
OP
T
TPONZ
Its not a new tractor, 2011 but new to me and yes its been like this since i bought it.
I thought maybe theres a setting for a timer giving the user time to get out to open
a gate before getting back into the seat. So long as im in the seat there are no issues.
   / Help with annoying problem #7
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Not familiar with the modern larger machines and the advancements made in the transmissions as well as safety.
Do you have the manual? Maybe something in it would reveal what's going on. Cause it sounds like some sequence of events isn't happening. Park brake set, lever in park and not neutral, etc.
   / Help with annoying problem #8
Jchonline
Elite Member
Red Feather Lakes, CO
Kubota L6060, KX040-4, M7060, X1100C, M62(S)
Check the manual? Might provide some insight.
   / Help with annoying problem #9
xtxpete
Bronze Member
Ontario
McCormick XTX 165, Case IH Cx 90, 445 skidsteer, Cub Cadet UTV, Farmall M
This sounds like you have either the E-plus or the E version that have the hydraulic range shift option. The way to get it back to your previous gear that it had been in on exit, is to after being back in the seat, depress/hold the range button on the front of your shifter handle and then pressing the upshift button!
   / Help with annoying problem #10
xtxpete
Bronze Member
Ontario
As you can see, I have an XTX and it is equipped with the E-plus option. Seems to work well, and I hope this trick works for you if you haven't figured it out already!
