Help with an F3060 axel pivot leak.
   / Help with an F3060 axel pivot leak. #11
I have a similar leak on my trusty F3060 which just got to 2,500 hours. ............................................Any tip is much appreciated !
Instead of explaining how to do it, how about you send me a private message with email address and I can email you a manual you can study?
:reading:
   / Help with an F3060 axel pivot leak. #12
I called my local dealer and they have the "OIL SEAL" (mentioned by the OP as 060) in stock (part 76611-12130, about $11.) Apologies for the dumb questions but here goes:
1) how does one remove that real-wheel drive shaft to replace that oil seal? Do you start by removing the two big bolts that hold the big V-shaped bracket that holds the shaft on the rear side? What next?
2) on my tractor this shaft has a roughly 1/2 inch front/back play, is this normal? The leak is not at either end but between the above-mentioned bracket and the rear case housing.
Did you figure out the drive shaft removal and oil seal replacement?
:steeringwheel:
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Erskine Skidsteer Dozer Blade (A59814)
Erskine Skidsteer...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
