Help with a grease fitting Kioti 3510
/ Help with a grease fitting Kioti 3510 #1
colorado816
Kioti ck3510 HST
Hi
I have a 2019 Kioti 3510 that I am having an issue with a couple of the grease fittings on the loader.
It appears as if grease is coming out the side of the fitting when I'm filling it.
I've attached a picture of one fitting and circled where the grease is coming out.
What causes this? And how do I fix it?
Any help will be appreciated.
/ Help with a grease fitting Kioti 3510 #2
You are pumping grease into this fitting. Where do you expect the grease that is already in there to go. It's gotta come out somewhere.
Try repositioning the FEL. The grease might come out the other side.
Your greaseable joint is, most likely, like mine. A solid rod with a small hole drilled half way down the center of the rod. Then a small hole from the center to the surface of the rod. The grease goes down the drilled hole and enters the "fitting" at the center via the hole drilled to the surface.
Thanks
/ Help with a grease fitting Kioti 3510 #4
FYI - I have one grease fitting on my FEL that WILL NOT take grease. I have to reposition the FEL and then the zerk takes grease just fine.
Thank you, I'll try that when I can get back to my machine.
/ Help with a grease fitting Kioti 3510 #6
This one grease fitting - on the FEL - could probably be permanently "fixed" by rotating the pin. In the normal - everything off - position, the little hole that feeds grease to the entire pin is sealed off.
I guess - out of the 24 or so zerks on the entire tractor - I'm just lucky it's only one.
2018 CATERPILLAR 930M WHEEL LOADER (A60429)
2018 CATERPILLAR...
2014 Ram 1500 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 Crew...
1997 JOHN DEERE 762B SERIES 11 MOTOR SCRAPER (A60429)
1997 JOHN DEERE...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
14C SCRAPER (A58214)
