Help.....washing machine clogged
/ Help.....washing machine clogged #1
chim
Elite Member
Lancaster County, PA
Kubota L4240, Ford 1210
Wifey decided to wash a small rug in our Maytag Neptune washer. The rug proceeded to shed a bunch of short pieces of yarn, and the machine won't pump out. Is there a filter I can clean? Thanks..............chim
/ Help.....washing machine clogged #2
Chim, I have no direct knowledge of the Maytag Neptune, but in general washers do not have filters on the drain line. If they did, you'd have to clean them everytime you do a load just like the lint filter on a dryer. Most likely the material from the rug has either clogged the pump or is interfering with the impeller.
Many years ago I used to work on commercial Speed Queen washers. I've seen bleach bottle caps block the tank drain and many, many baby socks stuck in pumps. I suspect that's the case with your rug material. I doubt that it clogged the hole in the tank where the hose attaches like a bottle cap would, but it probably made it to the pump and then stopped up the works. If you have a sharp bend or crimp in the drain hose, that restricted area could also clog easily.
/ Help.....washing machine clogged #3
Is this under warranty? Is so call them. If not you need to tip the unit up, access the bottom and see where the hose comes from the tub and where the pump is. Grab some channel locks and remove the hoses to access the pump. Should be able to do something with it to free it up.
/ Help.....washing machine clogged #4
On my Whirlpool, the pump is in the lower right front corner. Pop the top up and remove the front panel...
Alot of the online parts vendors have exploded parts diagrams that will come in handy...
/ Help.....washing machine clogged #5
I think the Maytag Neptune is a front loader, so that makes it a different "beast" from most. Not sure though. . .
Thanks to all who posted. It's fixed. Access is through a panel in the back of the machine. There are two small pumps there. An "L"-shaped rubber boot hooks the two pumps to the tub.
The tub has about a 3" outlet stub the boot clamps onto. The boot then makes a 90 degree turn and reduces in size, and has a pair of 1" "spouts" that clamp over the suction sides of the pumps.
One pump is for recirculating the water for washing/rinsing, and the other pumps the water out at the end of the cycle. The latter had the intake totally plugged with blue yarn from the rug. The impeller seemed to be bound up with the yarn.
I was pleased to discover that the pump hadn't bit the big one. All is well, and we saved the $97 (fro the first 20 minutes) service call. Thanks again................chim
/ Help.....washing machine clogged #8
</font><font color="blue" class="small">( I was pleased to discover that the pump hadn't bit the big one. All is well, and we saved the $97 (fro the first 20 minutes) service call. Thanks again................ )</font>
YEH! but wait till u get the bill from all the guys that helped /forums/images/graemlins/grin.gif Glad you got it fixed . Job well done.
/ Help.....washing machine clogged #9
BTW forgot to ask is that a front loader? and if so how do you like it?
</font><font color="blue" class="small">( BTW forgot to ask is that a front loader? and if so how do you like it? )</font>
Yes, it is a front loader. We love it, although this particular model has a tendency to develop mold at the door gasket. There's a class action suit right now concerning that. Our water usage dropped to 1/3 of what it was when we had the old machine.
It is easier on the clothes, and yet does a better job of getting them clean.
We were able to tap the town water line that runs by our place, so we get meter readings (the 1/3 is a real number)..................chim
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
1143 (A63745)
1143 (A63745)
