HELP... PTO ISSUES
/ HELP... PTO ISSUES #1
F350
USA
Red
I tried to repalce the PTO seal on my YM226 and when I pulled the PTO cover off a transmission assembly came out with it!!! I put it back together and now the PTO won't disengage. It stops turning with the clutch engaged.
Under load as the PTO shaft slows down you can hear a clicking noise coming from the PTO shaft.
How do I fix my tractor?? Any ideas??
My PTO was working fine before I tried to replace the PTO seal. I must have done something wrong @ reinstallation.
Are there any reinstalltion tips when installing the PTO gear cluster?
PTO lever position?
Any ideas would be appreciated.
/ HELP... PTO ISSUES #3
Disconnect all the shifting linkage before reassembly. You have to " feel ' the linkage levers go back into the shift slots as you push the assembly back in.
Thanks for the suggestions. I did notice that you have to "feel" the PTO gear cluster engage the internal shaft as you install it. I was unaware of the need to disconnect any linkages.
I guess I need to invest in a YM226 service manual.
Thanks,
2024 Wolverine X2 1000 R-Spec (A62679)
2024 Wolverine X2...
1143 (A63745)
1143 (A63745)
2022 EZ-GO ELITE...
Farm Hand Silage Wagon (A65640)
Farm Hand Silage...
1999 International F-8100 Truck (A62613)
1999 International...
2022 CATERPILLAR 259D3 SKID STEER (A65053)
2022 CATERPILLAR...
