help please! massy gc2610
/ help please! massy gc2610 #1
tractorman85
greenbrier ar
yanmar 2000
I have a customers tractor massy f compact gc2610 the loader works backhoe works but the 3point will not I have swapped the hoses around like I read in other forums but I have no results the 3point lift has never been used before. this tractor has been in a pond fully submerged under water and mud. I don't want to tare into it being it could be a fitting problem or manufactures defect. its gotta be something simple. if someone knows or has worked on this problem please help. I did check the fluid and is a little milky but not enough to cause this problem.
/ help please! massy gc2610 #2
I have worked on older tractors that have been through a flood. Water and mud in every low spot in every spot you can think of and then some. I would bet you have a job in front of you. Hope it goes well. Welcome to tractorbynet. Ed
thanks ed im fixing to tare into it I believe I have narrowed it down somewhat. we will see what I got in a little while.
/ help please! massy gc2610 #4
On my gc2410, the 3 point will only work when hoses are not connected to the backhoe. Maybe it's something as simple as that.
Brad
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2008 New Holland T2420 (A60462)
2008 New Holland...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
Kubota Z232 (A60462)
