Help please - L2850 is dead!
   / Help please - L2850 is dead! #21
DUCK,
Both the starter switch and headlight combo switch are subject to
water and dirt entry. If I recall, you can not turn on the headlights
unless the starter switch is on. That is why the combo switch has a
connection to the starter switch.
Replace at least your starter switch (about $60). Then you will also have
the ability to use the glow plug position (counter clockwise from OFF).
Oh yeah, don't let water get into the new switch(es). Good Luck.
   / Help please - L2850 is dead! #22
Duckguy said:
I hit the key, and everything stopped working and once again nothing works.
This sounds like a bad connection from the battery. You said that you changed the negative cable so that connection should be tight. I would check the positive cable where it bolts to the starter and make sure the connection is clean/good.
Vic
2018 Deere 323E (A53317)
2018 Deere 323E...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
yellow ball Trailer (A56859)
yellow ball...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2007 Volvo VNL Truck Tractor (A56436)
2007 Volvo VNL...
