Help please buying used 3 point tiller
/ Help please buying used 3 point tiller #1
etpm
Veteran Member
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Since I asked how much tiller my YM2310 can handle, and received many good responses, I have started looking for an approximately 5 foot wide tiller. Used. Unable so far, but it has only been 2 or 3 days, to find a Yanmar tiller. I will keep looking but I'm not hopeful. So it will probably be a tiller with who knows what name on it. That's OK as long as it will work.
So, what should I avoid? What will work? I have already decided that no driveshaft equals no sale. Aside from that though there might be other considerations. Like making sure the tiller won't hit the rear tires when raised. Is there a way to determine this? Without connecting the thing to my tractor? Any pitfalls to look for? For sure rotating the thing to make sure rotation is correct. Who knows? Maybe some off brand made for some off brand machine has the opposite rotation? But also to feel the gearbox to make sure it doesn't have any spots with higher or lower effort to turn. Or if it feels crunchy. Or if there is water in the oil in the gearbox. Or even if there is oil in the gearbox. Or just water. Or if a drive chain is so rusty that it is more akin to a drive bar. Anyway, you all get the picture. I have limited funds and so will probably need to shop around. But I have time and with some helpful advice from the folks here will probably be able to find what I need.
Thanks,
Eric
/ Help please buying used 3 point tiller #2
Yanmar has a worldwide and great reputation for making diesel engines. It does not necessarily follow that they would make good implements. Forget matching and find what works with your specs...then share. EA has some. I am too early in my search to help, but I am eager to hear suggestions.
/ Help please buying used 3 point tiller #3
Thanks,
Eric
Where you at in the world.
A little north of you on Whidbey Island. Like a few hours little, give or take. If you feel like dropping one off I'm only 3 miles from the ferry landing. I'll even pay for the ferry ride both ways.
Eric
/ Help please buying used 3 point tiller #5
The tillers made by Yanmar-Japan are as good as the tractors. RS-series etc. But you need the special top link components to stay clear of the tires. These till by a slicing action, perhaps to break up rice roots.
The tillers sold by Yanmar-US dealers back in the day were American made. ARPS made a lot of implements for Yanmar, Deere, and Kubota. Or the US 'Yanmar' tillers might have been made by Woods. At any rate they are generic American 3- point specs, they didn't need the special top link stuff. American tillers have more of a right angle and flat blade on the tines.
In my limited experience the Yanmar-Japan tiller does a great job, its slicing action isn't a disadvantage and its quality means nothing is likely to break. There's one feature that needs maintenance on these, and likely on any tiller that has been worked in wet ground: The bearing on the far end of the axle, opposite the gear/chain side, should be inspected and greased. It's a generic sealed bearing and a replacement is inexpensive if it sounds bad.
/ Help please buying used 3 point tiller #6
Eric
Quite a place, gonna do a MC trip to your neck of the woods next summer.
I'll keep my eyes open for a Tiller.
/ Help please buying used 3 point tiller #7
Hey neighbor! I don't have a tiller for you but I can probably almost see your house. I live in Conway overlooking the bay.
Sent from my XP8800 using TractorByNet mobile app
/ Help please buying used 3 point tiller #8
I have an old 6 ft yanmar tiller i bought at a good price , It was missing the top link parts and someone had done some torch work on it. I ended up making some brackets that moved the 3 pt pins out about 4 inches, I got a new driveshaft with slipclutch for it , now it works like a charm. Tilled up about 3 acres of food plots with it last year.
/ Help please buying used 3 point tiller #9
/ Help please buying used 3 point tiller #13
/ Help please buying used 3 point tiller #14
Looking at the pic. of the Vin. Plate I see that. Short run at that time I'm sure. Yanmar was packing up headed out of Dodge so to speak. looking well built and price cought my eye. 1741 A few of them even at 741 back then.
/ Help please buying used 3 point tiller #15
If you guys are looking for Yanmar or Kubota tillers, just come to Portugal and ship a container full of them. :)
We have them everywhere as they came with the "invasion" of the grey market tractors some time ago, usually somewhere around €300 to €700, depending on the shape. We don't really want them that much.
/ Help please buying used 3 point tiller #16
Careful, don't tell them this news in Poland, Greece, the Ukraine or Russia. You will no longer have a single Yanmar tiller left available in the country!
/ Help please buying used 3 point tiller #17
I have a 5' tiller from TSC. The tiller is more than what is spec'd for the tractor, but I have not had a problem with it. Be sure to have a slip clutch!! The tractor is 19 PTO Hp and about 2k #. I've run it in sand and clay and found rocks the size of baseballs with it. It makes a lot of noise when it hits a rock, but appears to be undamaged so far. The tiller is quite capable of pushing the tractor so I run it in 4WD in 1st gear to keep it under control.
/ Help please buying used 3 point tiller #18
Oh I'm sure they have plenty of that there too. Some of the best online sources for parts for these grey market tractors and tillers are located towards that area of Europe.
