Help on a disk cylinder please!
/ Help on a disk cylinder please! #1
BryanM
Northwest Ohio
John deere 2155, ford 1600
I just bought a ten foot disk I cant tell what brand (I think Mccormick). Anyway It Has I hyd clyinder and to hand cranks One for tong and one to adjust rear or tilt I think. Anyway The cylinder has one hose and I am not sure how it works. I plugg it into the tractor and it retracted the cylinder butthe tractor hydraulics seem to have stuck cause I cant move the lever. So I whent to the other outlet and nothing happened. after messing with the hydraulic control lever a little bit I got it to move again.
I was wondering if anyone had any suggestions where I can get a double action cyl for a 10 ft disk. The one on its dimesions are 2 eyelets both 1" and closed position aprox 22inches. other than that I dont know about stroke. So hopefully some one could point me in the right direction. Thanks
/ Help on a disk cylinder please! #2
Bryan,
You can find a replacement cylinder lot's of places...online and locally (like TSC). But you will need to know the stroke. You will have to remove the cylinder and hoses and manually pull it open (will be messy!) to get the pin-to-pin measurements both open and closed.
What you have now is a Single Acting cylinder that relies on weight to retract it.
I am not quite sure what you mean about your remote lever...is it working know? will the tractor engine bog down when it is operated in both directions?
Landhonor Mini Skid Steer Quick Attach Grapple Bucket (A66285)
Landhonor Mini...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
Hutchinson 8 x 32 Truck Auger (A66408)
Hutchinson 8 x 32...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
