Help on a B6100 4WD
/ Help on a B6100 4WD #1
farmall49
Looking at a '79 B6100 with 4WD. Need to know the specs. on it. (ie: 3-pt capacity, loader capacity, weight...) Please let me know if their is a site with the info. on these older model tractors.
Thanks in advance.
-Eric
/ Help on a B6100 4WD #2
Try a search on the kubota Site .
That link will give you some of the information you seek.
/ Help on a B6100 4WD #3
I can't answer all your questions, but I do know the B6100 is 14HP. I had one for a long time. They are very strong little tractors.
/ Help on a B6100 4WD #4
A couple of the earliest US Kubotas had reverse-rotation PTO's.
You might want to see if this was one of them, if you need the PTO.
/ Help on a B6100 4WD #5
I have a b6100E which is 2wd....does this one have a HST trans...i'm assuming its gear since its a 79. The lift capacity on the 3 point is only 300 pounds according to my manual, it has 14 hp. I dont believe it has reverse PTO well mine doesn't. If u need more help just post again
/ Help on a B6100 4WD #8
I have a '78 B6100DT (4wd, gear tranny). I'll look up the specs in my owner's manual when I get home tonight and post them.
Bill
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
2017 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2017 Peterbilt 320...
John Deere L100A Riding Mower (A65579)
John Deere L100A...
Lowe Pontoon Boat and Trailer (A65579)
Lowe Pontoon Boat...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
Case IH 5100 12ft. Soybean Special (A65640)
Case IH 5100 12ft...
