help needed
/ help needed #1
chappo2011
lismore nsw australia
kubota L4200
hi all been trying to plant millet but i hit a prob the grass is that thick my plough wont cut it i cant burn it an spraying is out i have tryed a mullboard plough an disk a single ripper just balls up with grass i have just ran out of ideas
/ help needed #2
A moldboard plow if properly sharpened on the point and set correctly will turn the heaviest of sod. Check the linkage on the 3rd arm and maybe sharpen the point a little and try it again. The old Pan plows (dont know the proper name for them) that used 30" or so diameter discs also always worked good. Any tractor of 20 HP should be able to pull 2 of those if you can find them.
/ help needed
not real keen on the pan plow as we have a lot of truble with the ground paning thats y i can use the hoe was starting to think of black plastic but i cant get it in 10ac lots lol
/ help needed #4
Sure sounds like the plow isn't sharp or more likely set up properly. If I don't have the coulter set right on my Brinley, I have all kinds of problems.
/ help needed #5
can you hire some one with some heaver better equipment to turn the soil/sod
/ help needed #6
need some more details about the plow.
a turn plow is by far the best option for small HP tractor applications when it comes to tearing up virgin sod.
/ help needed
its a ford 2 forrow mullboard plough see the grass i blocking up as it get to the 2an forrow an it wont let it pass though been thinking letting it go to hay cut it as short as i can then ripping it
/ help needed #9
Oh heck...here's a google search. There are even videos on set up.
(url)Google)
Wooden Glider Chair (A64557)
Wooden Glider...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
2022 EZ-GO ELITE...
2023 TOPCAT 4IN1BCT (A67148)
2023 TOPCAT...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
2014 FREIGHTLINER CASCADIA CA113DC T/A 6X4 DAY CAB TRUCK TRACTOR (A67148)
2014 FREIGHTLINER...
