Help! Mystery Part on Ground
   / Help! Mystery Part on Ground #1
Used4310
John Deere 4310
I found a mystery part while walking a tractor path after doing some brush hogging yesterday. I have a 4310 and an old brush hog whose brand is long faded. There is a small chance it is from something else but very likely it is one of them. The PTO was not running while I passed this section yesterday, which has me worried it is from the 4310. I am not that experienced with tearing down the tractor, so don't recognize the part. I did a quick inspection and nothing jumps out at me as wrong.
Seems like it was about 2" diameter, about 1/16"-1/32" thick, and has small castellations on one side.
The part will hold a bend so I don't think it is spring steel but not sure if after going through whatever happened it would maintain that property anyway.
   / Help! Mystery Part on Ground #2
That looks like a bearing race retainer, or part of one. I'd check the brush hog and see if any spindles are about to come apart.
   / Help! Mystery Part on Ground #3
almost looks like a ball bearing cage, double check the tail wheel on the cutter and be sure you don't have a bearing that's come apart
   / Help! Mystery Part on Ground #5
OP you were observant enough to notice. Most people would walk right past and not notice it.
Good save
2010 International 4400 National Crane 300C 56FT 8 Ton Crane Truck (A50323)
2010 International...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A52748)
Adams FL24...
2018 JLG 4045R 40ft Electric Scissor Lift (A50322)
2018 JLG 4045R...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
