HELP! My Backhoe won't swing left!
   / HELP! My Backhoe won't swing left! #61
Great! Have intermittent problem on left swing and boom down on the M59. So far been a temporary inconvenience but could cause a real problem. Suspected a similar cause but wasn’t sure I had the skill to attempt repair. Any pictures or additional documentation would help. Have good hydraulic shop to take parts to for them to help. Wonder if higher durometer or Viton o-ring would be better? Wonder why it tends to effect the left swing?
Repairs with the backhoe on or off the tractor?
Thanks for exploring the unknown and sharing.
   / HELP! My Backhoe won't swing left! #62
If the problem is in an overload relief valve (OLRV), they always come in pairs, so there are two of those relief valves on each control valve in the control valve stack that has them. One OLRV sits on top of the control valve and the other one underneath facing down.
Overload relief valves respond to outside pressure on the system, not hydraulic pump pressure like the regular relief valves do.
The shop manual illustrations are very good at showing fluid flow as each control is activated. After a little study, you can see that the relief vaves for "swing left" and "boom down" are both sitting on top of their control valve rather than underneath. I wonder if that would explain the handedness?
The parts book doesn't show parts for the OLRV, but the shop manual shows them in great detail. There is quite a bit more to say about those relief valves - but I'll wait until we find out if that is the part that "Ished" fitted with new O rings....or if it was some other control valve part.
BTW, the L45 and M59 backhoe control valves and reliefs look the same or similar. The parts book for the M62 hoe shows its control valve as is very different and more rebuildable.
rScotty
   / HELP! My Backhoe won't swing left! #63
I think these intermittent issues either no swing or no down pressure are very likely the port relief/overload relief valve stuck open. These reliefs are not simple direct acting reliefs. They are pilot operated which are a more precision design with more small moving parts , orings, springs and small orifices prone to issues.
Nice thing is there just a cartridge type that just thread into the directional control valve, easy to remove for inspection and repair. If it was me I’d pull the one out that’s on the pressure port for left swing , disassemble and inspect for any contamination, plugged orifice , broken or bent springs, worn orings and a good cleaning. Don’t forget to mark the position of the set screw before disassembly.
   / HELP! My Backhoe won't swing left! #64
Here’s some good info from the pages of my Volvo excavator service manual, they look to be almost identical to R Scotty’s illustration
   / HELP! My Backhoe won't swing left! #65
So wanted to update everyone again I had a very similar problem to the no swing but instead main boom would just fall down. So I did what I did to the swing valves removed them took them apart and the little o ring was bad on the one. So I replaced all orings put it back and bam fixed. So just waiting for the last set to act up for the curl and I'll replace those the same way.
So if anyone is having this problem do the same yourproblems will be fixed. It's a poor valve design and allows the inside of the oring to chew itself up
(2) FIBERGLASS LADDERS (A58374)
(2) FIBERGLASS...
HUSQVARNA RIDING...
2013 John Deere 27D Mini Excavator (A55973)
2013 John Deere...
CASE INTERNATIONAL 4R DANISH TINE CULTIVATOR (A52708)
CASE INTERNATIONAL...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
