HELP !!!!! Major Problems with Kioti DK45S
Status
Not open for further replies.
/ HELP !!!!! Major Problems with Kioti DK45S
Bearclaw
Think about it this way your working in an area where there are walls with staff moving around construction material and a tractor is being operator in relatively close proximity such as preparing a site to pour concrete. ( Believe it or not this actually takes place all over the planet.) The operator of the tractor is moving in a low gear having confidence in his tractor as he should and all of a sudden it goes full throttle headed for your staff to pin them against the wall and possibly cut them in half. Now do you get the picture!!! Can you smell what I am cooking!!! Sometimes people don't have time to respond that quickly. When trying to move it from the site with everyone out of the way the clutch started fading and would no longer engage.
Thats It!!!
/ HELP !!!!! Major Problems with Kioti DK45S #22
curious, did you say the only way to shut it down was to put it in high gear and stall it, is the fading due to the high rpm and clutch slip when stalling, if it fades how can it stall, the CK20 has a fuel cutoff knob, can one be added to yours, all tractors have one at least all I have used, even my 644 Deer loader has a pull shutoff, on my skidsteer the fuel shutoff is a solonoid and the shutoff is spring pressure, find it difficult to believe fuel pressure would hold it open
/ HELP !!!!! Major Problems with Kioti DK45S #23
No fuel shutoff knob on my CK30. Key only which sends and stops power to a solenoid on the pump to cut fuel. There is a means on the pump to add an aftermaket fuel shutoff knob however.
So now it sounds like the guy was poking along operating carefully in a tight environment when all of the sudden, out of the blue, on a gear tractor, the throttle went to 100%. I could understand how that has high danger potential. In a wide open field there would be plenty of time to react.
/ HELP !!!!! Major Problems with Kioti DK45S #24
It is easy to say, "push in the clutch" "press hard on the brake" "move shifter to neutral" but things happen faster some times than our brains can resolve, simply said how many times have we said "that was stupid", I for one think a fuel cut off should be standard
/ HELP !!!!! Major Problems with Kioti DK45S #25
Hi Guys :confused:
For the benefit of you who are not sure how all this works, I'll try to explain it in laymans terms as best I can for you all.
In an in-line injection pump like is fitted to the these tractors, the rack is a rod with teeth cut into the side of it, when you operate the throttle, the governor and control linkage from the throttle act on the rack pushing it back and forth in the engine. As mentioned in earlier remarks, this rack then acts on the elements in the injection pump which also have teeth cut into them. So basically you are turning lineal motion into radial motion.
Push the rack in one direction and you turn the elements to open the fuel and push it in the oposite direction, the rack will cut the fuel down (more revs or less revs).
By the sounds of what has been said here, a tooth has broken on the rack which in turn has jammed the rack in the high rev range. Now to shut the engine off, the stop control both manual and electric act on the rack to push it to low-no fuel position. Because the rack has been jammed on the high side, no amount of pushing or pulling on the rack will move it to the fuel off position. In most cases (but not all) of in line pumps with a rack system like this, they are spring loaded to no fuel (stop position).
So hence the inability to shut the engine down. Even if the engine were fitted with manual shut off, the same would apply.
After this, the only way to stop the engine will be to stall the engine with a high gear, brakes and clutch. Taking into account that the engines produced today are designed to have high torque low down in the rev range, this may explain why the clutch may not be feeling the best any more.
As "Laurencen" correctly mentioned, in a closed enviroment, the reaction times need to be faster, even in low gears, especially when it happens in a split second, maybe high revs in low gear to move close to a wall and then the engine doesn't come back off high idle as you expect.
For a comparison, check the reaction time on the open road in your car when a hazard is identified??? I think you will all be surprized just how long it takes and how far you actually travel before you apply the brakes???:(
I hope this is of help to you all to understand a little more of what may have happened here. The main thing to remember and learn from all of this is to be very careful when working around machinery and be aware of your surroundings.
Sorry if this is long wided or if I sound like I am preaching.:)
/ HELP !!!!! Major Problems with Kioti DK45S #26
The whole thing that gets me is if your are having a major problem like this, why would you continue to use it.
The clutch should not have faded 1 or 2 times of stalling, several times of stalling I can see.
All I know is if I was in a closed in area and had this kind of issue I would not be continuing to use it until it was fixed.
My biggest problem with the thread is the fact they he is claiming that this is a major defect in a product.
And we should be alerting everyone.
I sorry but I have over 30 of these models out in the feild and have yet to have the same problem.
I understand what has happened a I am not discounting it but I really belieave that it is a isolated issue.
As far as tractors having a manual fuel cut off I am all for it....
But I checked some other brands of tractors on my lot new and used and they have no manual cut offs.
Seems like the industry is going electrical.
/ HELP !!!!! Major Problems with Kioti DK45S #27
I know nothing about diesel engines. But, why doesn't turning the key off prevent spark for ignition?
/ HELP !!!!! Major Problems with Kioti DK45S #28
Hi Guys
Wallace, I agree that it is not a major problem and it appears that some one got a good fright at the time and hence hipe all through this thread. Without having seeing where the tractor was working, it probably should have been fixed where it was as you say, but whos to know that it may have had to be moved off the sight for work to continue.
The reason for my long winded explanation was to try to calm some of the comments here. Is the tractor actually back up and running yet? :confused:
I'm all for the second option as well, but as you say it seems the manufacturers are all going for electric shut off.
Coasterez
A diesel engine does not have electric spark ignition, the ignition is produced by compressing fuel and air and hence while there is fuel going in, there will in most cases also be air going in as well and hence fuel + air + compression = ignition. I hope that helps.
/ HELP !!!!! Major Problems with Kioti DK45S #29
Coasterez,
Well, since you'r a good guy we'll let you slide on this one. There could be all sorts of engineer jokes flying here, the temptation is almost unbearable.
Diesel engines have no spark plugs. Compression of the fuel ignites the combustion.
I love the funny looks on my friends faces when I ask them to help me change the plugs on my tractor.
Edit: Whoops, Tractech beat me to it - He's always so serious.
Status
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-150...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
Sterling 9500 (A61307)
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
