Help Kohler 8 hp
/ Help Kohler 8 hp #1
Mattc8832
West Virginia
John Deere 3032e,Snapper Pro SW20 and s200, Stihl Handhelds, BCS 830, Yamaha Rhino 700, 2 - Gravely 5260, New Holland LS 45 , 6,10 by 14 Trailer , Woods BH 6000 Towable Backhoe, Honda 21 Self Propelled, Exmark Commercial 21and shop full of tools
I tore down the kohler 8hp well I only too the head off and the piston and rod out. I installed new gaskets , piston , rod and rings. I didn't remove the cam , crank or valves. Once I removed the piston and rod I turned the crank a couple of turns not thinking them I assembled a new piston and rod and put the engine back together. Cold I have the valve timing off by turning the crank. I believe both valves were closed when I installed the new piston.
/ Help Kohler 8 hp #2
As long as you didn't un-mesh the gears, you didn't change valve timing.
2022 EZ-GO ELITE...
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59911)
2015 ISUZU NQR 4X2...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
Mini Skid Steer (A60352)
Mini Skid Steer...
