**HELP** JD L120 Throttle issues
/ **HELP** JD L120 Throttle issues #1
Cruiser787904
Altoona, Iowa
JD L120
I had to pull the engine to replace a leaking gasket. When I pulled the pan I had to remove the linkage attached to # 28 in the image link below. I now have it all back together and when I fire it up it revs to the moon. So I turn it off and take a look and the only thing I tampered with was the linkage attached to #28. I noticed that when I closed the throttle it does not seat against the idle adjustment screw/stop. So after fiddling with it I ended up putting a secondary spring in to bring it all the way back to the adjustment screw/stop. Now it idles nicely but when I go to throttle up it revs normal at half throttle and revs to the moon anywhere above that.
Any one have a proper procedure for setting the linkage I had to remove correctly? What else could the the problem?
Alright I now know this it the governor mechanism and watched a you tube on adjusting it correctly. Going out now to see if this adjustment fixes it....
Well I had no luck....it operated fine until the oil leak which prompted me to change the #11 gasket. When I took the pan off to replace it the gasket was sucked into the case. Now with it back together I am guessing the governor took a dump damaging that gasket. When I took it apart I am assuming the governor was allowed shift and is no longer working. Based on what I have seen and read the motor is done for... Anyone with advice please chime in....
1980 Great Dane 102'x48' Lowboy (A64912)
1980 Great Dane...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2019 FORD F-350 SUPER DUTY (A67714)
2019 FORD F-350...
2019 Dodge Durango SUV (A66738)
2019 Dodge Durango...
2021 JCB 3TS-8T TELESKID (A65056)
2021 JCB 3TS-8T...
2005 CATERPILLAR TH460B TELESCOPIC FORKLIFT (A65056)
2005 CATERPILLAR...
