HELP!! I've got a e20 mini x with left track problems
/ HELP!! I've got a e20 mini x with left track problems #1
Tommy g
Bobcat e20 mini x
2 016 e20 mini x with weak movement fwd and reverse until I give joy stick a little movment then it moves better but not right any ideas? Please shoot me some ideas thanks tom
/ HELP!! I've got a e20 mini x with left track problems #2
When did you last change the oil & filter(s) ?
Cleaned the suction screen ?
/ HELP!! I've got a e20 mini x with left track problems #3
If the joy stick you refer is the lock out up (disengaged pilot controls) it provides a little more flow for the drive motors.
But I dont think that's the main issue, as spanner say check the little things first, Hyd level, filters, suction filter etc.
Then raise it off the ground and cycle both tracks - they should run the same speed. Then try each one touching the ground to see if one is weak, or put your bucket and blade down and try to run the tracks.
Last, your drive motor(s) may be getting weak, 3-4000 hours or so is typical life depending on conditions, fluid changes, drive maintenance etc.
/ HELP!! I've got a e20 mini x with left track problems #4
I have an E20 Bobcat also. I also have issues with the tracks. It seems that its mostly when I'm traveling in high speed.
I changed one of the track motors about a year ago and that didn't seem to help.
Where can I find the suction filter? I don't think this model has one.
/ HELP!! I've got a e20 mini x with left track problems #5
There is a main hyd canister filter in the engine compartment and then the final drive oil should be changed with gear oil every 500 hours I believe.
MASSEY FERGUSON 4710 TRACTOR (A64280)
MASSEY FERGUSON...
2014 Link-Belt 350X4 Hydraulic Excavator (A61572)
2014 Link-Belt...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Can Am Defender (A63688)
Can Am Defender...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
