Tractor Sizing Help in sizing tractor
/ Help in sizing tractor #21
I would say that it depends on if you want to clear the 7 acres yourself, or have it done and then just "maintain" it. If you want to do it yourself, you need the bigger 5000 E series with a strong FEL, MFWD, and a grapple on the FEL. If you have it done, you could get by with the 3520 or 3720 and be able to use the 6' implements reasonably well.
Or a JD 110TLB with hyd thumb on the backhoe and a root grapple on the loader. Then you could use those 6' implements "reasonably well", too! :D
AKfish
2017 NISSAN NV2500 4x2 VAN (A59911)
2017 NISSAN NV2500...
2017 Caterpillar 336F Hydraulic Excavator (A61572)
2017 Caterpillar...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
2021 PETERBILT 388 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2021 PETERBILT 388...
2022 Case 5550 Trident Spreader LOW HOUR (A63688)
2022 Case 5550...
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
