Help, I'm losing my teeth
/ Help, I'm losing my teeth #1
gmsssi
Platinum Member
Western Pennsylvania
Kioti DK45s
Help, I\'m losing my teeth
I have about 15 hours on my new BB and I've lost 4 of my scarifiers teeth! Whats the deal and am I doing something wrong?
/ Help, I'm losing my teeth #2
Re: Help, I\'m losing my teeth
Greg,
What brand BB? What version (standard duty, heavy duty)
What are you hitting/snagging with them?
Are they breaking off or are the locking pins coming loose and you are actually losing them because they slip out?
It's a Kioti (Midwset) BB-30 (heavy) 72". The teeth a peened on, not pinned on even though they have the holes for pins. Definitely going with pin replacements!
Rocky and dry terrain. If I'm losing them, I ain't finding them......
/forums/images/graemlins/smirk.gif
/ Help, I'm losing my teeth #4
3 things: #1, the rocks you are hitting are TOO BIG. Just hit the smaller ones and you won't have this problem. /forums/images/graemlins/wink.gif
#2, I've not seen the "30 series" Midwest blades, could you post pictures here so we can see what you are talking about?
#3, could you also post pictures in the following thread? Box Blade Photo Comparison thread
/ Help, I'm losing my teeth #5
Greg, Several years ago, I bought a Midwest BB from Corriher in NC and had the same problem. The nice folks at Corriher responded that I needed 'hardened' teeth for the rocky New England soil. They sent me a new set at no cost to me. But once I saw how they were attached, I took the new teeth and the scarifiers to my local welder. He removed the old teeth and welded on the new ones. I have not lost a tooth since.
I will grant that the attachment method is designed that way on purpose. The teeth are supposed to pop off rather than break a scarifier. But since the glaciers were not kind to us nor'easters, I am perfectly satisfied with my welded teeth. Just make sure that the rock is less than 50% of the size of your BB. /forums/images/graemlins/grin.gif
back
side with missing teeth
other side, fuller shot
1996 Polar DOT 407 Single Comp Insulated Diesel Trailer (A64194)
1996 Polar DOT 407...
3269 (A63117)
3269 (A63117)
2011 International DuraStar 4300 Mobile Food Prep Truck (A64194)
2011 International...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
ALUMINUM CUTTING BOARD, (2) POLY CUTTING BOARDS (A64278)
ALUMINUM CUTTING...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
