help identifying u-bolt
/ help identifying u-bolt #1
GBBBBB
Moorefield WV
Kioti CK3510H
New CK3510H, ~ 12 hrs. Using the backhoe I started to lose power. Then a leak developed blowing hydraulic fluid around. It looks like the hoses to the aux valve worked loose. I found this u-bolt on the ground under the tractor. Just like it is in picture, with nuts attached. I don't know where it was or how it could have worked itself loose with bolts attached?
/ help identifying u-bolt #2
Sorry, can't help you on where it came from. Are you sure it came from the tractor? Most U-bolts have a flat piece of plate they're attached to that goes under the bolts and is used to squeeze or clamp down on whatever it's holding. Nothing obvious from the location of where hydro fluid is coming from?
/ help identifying u-bolt #3
On my CK35 that U-bolt secures the hydro hoses just above the swing cylinders. There is a bracket with two holes in it, nut on each side of the bracket. Two nuts came loose.
2014 Chrysler 200 Sedan (A64557)
2014 Chrysler 200...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
CASE 850M WT CRAWLER DOZER (A64277)
CASE 850M WT...
