Grapple Help identify
/ Help identify #1
RitchElbe
Millers Creek, NC
John Deere 4100 / Jim Dandy
A buddy emailed this pic to me but failed to send link to the page.. he clears his history nightly and we have been unable to find it again using the same search. Attempting to ID the grapples BC-3000.jpg
/ Help identify #2
Says it right in the picture: Brush Crusher. Made by Westendorf.
I'm still debating getting a pair for my Kubota, cost is not unreasonable, but the company seems to have control issues and they're pretty stingy with information. Not a great reputation here on TBN.
/ Help identify #5
At only 140 lbs for the 3000 model, I can see the advantages to a smaller lift limited tractor. No SSQA hardware and lighter than any grapple.
/ Help identify #6
Tom, RH, I have a pair mounted on a 35 hp Century (older Branson). If you are moving a lot of brush and small logs they can't be beat. it usually takes me about 20 minutes to attach them to my tractor as you have to remove the quick attach system. I have a loader made by Humpolec that was sold with the Century tractors when I bought mine. They are indeed lighter than most attachments which enables you to pick up a lot. If you are cutting a lot of firewood they are the best aid for getting the log off the ground to cut it up. Willie Jones
/ Help identify #7
Good way to twist a loader frame with the two arms not tied together.
/ Help identify #9
Actually they are very stable and i have had no twist in mine. But I do not try to abuse them and go slow when loading. You can actually use them to load chippers with saplings if you are clearing underbrush. Saves a lot of labor. W Jones
/ Help identify #11
The loader frame should be strong enough not to twist with max lift on one side.
The two arms are not "tied together" with a bucket or a grapple, as far as resisting a twist with the weight all on one side.
/ Help identify
Just last night I was wondering if anyone saw my post and woke up this morning to emails alerting to post from weeks ago... crazy just crazy... Thanks Troops!
/ Help identify
The beauty of being seasoned welder / metal worker.. I saw right away none would work on the JD 4100..so I will need to work up a design of my own... let the old brain cogs get to grinding
/ Help identify #14
I have no experience with Westendorf, but I'm pretty sure that at least one person within the company has an account here and has posted a time or three. Maybe they will read your post and take a hint?
/ Help identify
Tell you what Paul, get me an upgrade on my cell phone that will allow me to see that writing like one does on a home computer..and we'll be square..it came thru my cell,, within mins uploaded it to here.
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
Dirt Dog 3PBU Hay Unroller (A65579)
Dirt Dog 3PBU Hay...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
Caterpillar 446B Backhoe Loader (A66285)
Caterpillar 446B...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
