Help Identify this UTV
/ Help Identify this UTV #1
Yokurto
JD 2010 high crop
Hi guys, I decided to start work on this Pug type vehicle since we are locked down. I bought this thing 25 years ago and it finally got to the top spot to get repaired . I was told it is a Pug but guys I have talked to said it isn't. It is, best that I can tell, built around 1962-65, powered by a Onan NHC 25 hp motor coupled to a hydraulic pump. The steering is articulated with a hydraulic cylinder, the driveline is hydraulic motors coupled directly to the Dana 27 rearends cutdown and shortened axles. The front "nose " has been cut off I suppose it was smashed and the previous owner figured it would look better cutting it off. It is all steel, pretty crude construction but I think factory manufactured not home built. Any help is appreciated
/ Help Identify this UTV #2
It sure doesn't look like any PUG I have worked on. They had a different joint and had a manual trans, driveshaft, normal diff.
/ Help Identify this UTV #4
It looks like a Taylor-Dunn airport or warehouse tug.
Maybe an early E 451 {w/o overhead guard} with what's left of a trailer?
/ Help Identify this UTV #5
Long shot - is it some kind of old Cushmann perhaps?
/ Help Identify this UTV #7
Lets not get hasty here. The body looks straight and complete. Tires and paint will go a long way to making it respectable. Seats are easy to find and install. And the cat looks in very good shape. How is the engine?
/ Help Identify this UTV #8
I was thinking Cushman also, but all the Cushman's I've seen are more square in the nose. I also haven't seen an articulating one, which doesn't really mean anything, they could easily be out there.
/ Help Identify this UTV #9
View attachment 648006View attachment 648007View attachment 648008View attachment 648009View attachment 648006View attachment 648007View attachment 648008View attachment 648009
This has all the earmarkings of a PUG possible the early models were made of steel before the went to fiberglass but its built with same footprint
/ Help Identify this UTV #10
Hey Randy welcome to TBN!
We've all done it and occasionally I still do, but this post is from 2020 and the last post was in 21.
Maybe you're post will revive it. All to often we never get to hear the rest of the story. 👍
/ Help Identify this UTV #11
It's a jacobaon they bought out pug and went to steel body
2016 FORD F250 EXTENDED CAB PICKUP TRUCK (A66091)
2016 FORD F250...
2011 PREMIER PUMP AND POWER 3HC-DM16 TOWABLE DIESEL PUMP UNIT (A67714)
2011 PREMIER PUMP...
2025 Kioti CS2530 - like new!
2025 Kioti CS2530...
2011 Ford F-150 Pickup Truck (A66736)
2011 Ford F-150...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
x (A68191)
x (A68191)
