Help!! I am an idiot!!
/ Help!! I am an idiot!! #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I just got my new Fimco sprayer and went to hook it up to the tractor. My problem with 3pt hitches has always been some rust or alignment problems so a piece of wood and a sledge hammer have always worked. Well this time it is the pins painted. So I pounded on one arm until I got it on about 1/2 inch. Now it will not come off or go one any more. The other side I took a sander to the paint so it slides on easily. I have also sprayed the stuck pin with WD40. Any thoughts on how to get it off?
Eric
/ Help!! I am an idiot!! #2
Try xylene in the joint to dissolve the paint.
Thank you for all the suggestions. I took a long 80 year old 2x4, very hard, and started wacking on it. This way I had more room to swing. Still would not budge. I then tapped lightly directly with the sledge hammer on the 3pt arm and it came loose. Quickly sand and all is good to go.
Thanks,
Eric
/ Help!! I am an idiot!! #5
Might I take this moment to suggest that you can support TBN and all this helpful information by purchasing Pat's Easy Change online on this very site?!? It will not only support TBN, but it will make your implement changes swear free, bloody knuckle free, and the sledge hammer or 2x4 will no longer be unwitting participants in ritural tractor beatings! /forums/images/graemlins/wink.gif
John Deere X380 Riding Lawn Mower (A66285)
John Deere X380...
WESTINGHOUSE PORTABLE ARC WELDER (A64276)
WESTINGHOUSE...
HARDEE LR40142 DITCH BANK MOWER (A64278)
HARDEE LR40142...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
Club Car Carryall 2 Electric Utility Cart (A64553)
Club Car Carryall...
