HELP! Howard Rotavator pto shaft
   / HELP! Howard Rotavator pto shaft #21
SOLUTION. I ended up having an adapter machined to go to a typical 6 spline shaft. Then added a shear pin.
Crazy timing for me to find this thread...
I just got a Howard Rotavator E4 series. Missing the tractor-side PTO shaft. I am thinking of removing the clutch and having an adapter made to fit the 10-spline shaft.
Did you have a shop machine the splines, or did you find a coupler to modify?
   / HELP! Howard Rotavator pto shaft #22
If you have the implemrnt side of the PTO shaft, why not just get the tractor half shaft?
Tube is rectangular, yes?
   / HELP! Howard Rotavator pto shaft #23
No, it is some irregular spline pattern.
   / HELP! Howard Rotavator pto shaft #24
I'm going to a local shop tomorrow to see if they can take the clutch friction plate and make an adapter to a 6 spline out of it. I like the idea of using the splines on the gearbox shaft as opposed to drilling it and using a shear bolt.
2004 Ford F-150 Ext. Cab Pickup Truck (A59230)
2004 Ford F-150...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2019 KENWORTH T680...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
Volvo EC220EL (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
