HELP! Howard Rotavator pto shaft
   / HELP! Howard Rotavator pto shaft #21
SOLUTION. I ended up having an adapter machined to go to a typical 6 spline shaft. Then added a shear pin.
Crazy timing for me to find this thread...
I just got a Howard Rotavator E4 series. Missing the tractor-side PTO shaft. I am thinking of removing the clutch and having an adapter made to fit the 10-spline shaft.
Did you have a shop machine the splines, or did you find a coupler to modify?
   / HELP! Howard Rotavator pto shaft #22
If you have the implemrnt side of the PTO shaft, why not just get the tractor half shaft?
Tube is rectangular, yes?
   / HELP! Howard Rotavator pto shaft #23
No, it is some irregular spline pattern.
   / HELP! Howard Rotavator pto shaft #24
I'm going to a local shop tomorrow to see if they can take the clutch friction plate and make an adapter to a 6 spline out of it. I like the idea of using the splines on the gearbox shaft as opposed to drilling it and using a shear bolt.
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
2402 (A60432)
2402 (A60432)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
1996 Ford Ranger Pickup Truck (A59230)
1996 Ford Ranger...
UNUSED RAYTREE RMBD72-72" HYD DRUM MULCHER (A60432)
UNUSED RAYTREE...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
