Help! Grease Coupler won't fit
   / Help! Grease Coupler won't fit #1
flienlow
Bronze Member
Snohomish,WA
Kubota BX25D, Kubota U25 Mini Excavator
I have a Kubota U25 Mini with a Thumb, and use a Lincoln Air Gun to grease it. Everything is fine except for 1 fitting on the thumb. The grease coupler is too big to fit in the hole that the Zerk is recessed in. I went to tractor supply and a few other places to see if I could find a "thinner" Grease Coupler, but I was unable to. Any ideas?
   / Help! Grease Coupler won't fit #2
Grind down the coupler so it'll be smaller and fit.
I didnt know those Grease needles would work. I will give that a try. Thanks.
   / Help! Grease Coupler won't fit #6
Nipple and a coupling will bring the fitting out closer unless movement closes off the hole in question. A picture would help on ideas.
Ron
adding to. you may need to physical move the backhoe to access a zerk.
TIP: twist greese gun end say approx 1/2 a turn if will not fit on or will not come off.
JOHN DEERE LOT NUMBER 123 (A53084)
JOHN DEERE LOT...
Electric Concrete Mixer (A51573)
Electric Concrete...
New/Unused Quick Attach Rock Breaker (A51573)
New/Unused Quick...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2005 TerraGator 8104 (A53472)
2005 TerraGator...
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
