Help! Damage to cylinder
   / Help! Damage to cylinder #1
JackDWaller
john deere 2320
Hi All. I am in a pickle that I'm told will cost me $554 plus tax - for a new bucket cylinder for my JD 200cx loader. I won't go into the gory details except to say that a chain hook snagged the hose attaching stud (rod end) and cleanly ripped it off. It doesn't look like the cylinder has been impacted except for the small clean circular break of the stud from the cylinder.
I am hoping it can be welded back on somehow so with that in mind I've removed the cylinder and the snap ring thinking that the piston rod should come out, but no luck. Dealer says a firm smacking pull should do the trick but I've done that with the other end secured firmly and nothing moves. In fact looking at the slot and the ring I'm puzzled as to how that ring retains anything.
If the stud can't be welded back in place then another thought was to machine a press fit ring that would have a stud in it that would align with the old hole and maybe run a tiny weld bead around the ring or maybe just sealant. At any rate, I think my odds of success (assuming welding) are best if I can get the cylinder apart.
Any helpful hints would be most welcomed. Is there likely an alternate source for the cylinder that could be cheaper?
Jack
   / Help! Damage to cylinder #2
Other than doing it your self, I would take it to a hyd shop and let them do the new port. They probably have done something like that before.
Be sure to get a written estimate, before you leave it.
Two pieces of good advice - thanks. I may still deside to go that route. I have no idea what these places might charge. The more I think about it the more I believe I could come use my lathe to come up with a haywire work-around. I have more time than money ;)
I did find the thread from 2008 - "JD Hydraulic Cylinder Rebuild Help? " and it seems to address my situation but I don't have any rebuild kit with any "special tool" and I don't fully understand what is going on here. Seems to me if the retaining slot were interfering with another ring that must come out, that at least some movement outward would be first observed and then it would hang up??
Jack
   / Help! Damage to cylinder #4
Jack
Jack,
If you pulled hard enough to rip the coupling/stud off of the cylinder it also may have bent the cylinder housing some in that area which could pinch the end cap or the piston into the cylinder. Just a thought, are there any threaded holes in the end cap where you could put bolts in and use them to try and pull the end cap out?
Roy
Thanks Roy. The chain hook caught right next to the cylinder and although I agree with your concern, it appears that it's a clean break with no deformation. Certainly the piston slides perfectly from end to end. However, perhaps this has something to do with the problem getting it apart, but I suspect that I'm not approaching the disassembly properly. I think I'll abandon trying to disassemble the cylinder. I'll plug the hole when cleaning the paint off that area on the cylinder
Since it's now a few hours after the accident, I have settled down to thinking a bit more clearly and there is no way I will spend $600 on a cylinder. I plan to weld/machine a split collar, much like two connecting rod caps that will pull together over the missing nipple (hole). I'll press and weld the old nipple in place in the collar/cap after I machine off a section of its thread (there is just enough length). There is ample room for a modest collar when the cylinder is fully retracted. After buffing off the paint I plan to use a touch of silicone and then pull the halves together.
So that's the plan, barring better advice from the good TBN folk.
Jack
   / Help! Damage to cylinder #6
Hello Jack,
After all this I would buy a replacement cylinder
from Prince or Parker and not fool with it as you
will spend much less money.
Thanks. If I hunt up a non-JD cylinder that appears to be closely sized, is there any issue I might run into relative to a mismatch with the other side? Haven't had much hydraulics experience.
Jack
   / Help! Damage to cylinder #9
Jack
Somehow I don't think that will be a satisfactory repair but, as they say, it's your cow...milk her anyway you want. :D
I did find this on the interweb...not sure if it pertains to your cylinder or not, but the possibility exists that it does so here you go! Hopefully something there here help. :)
http://golftechs.us/Manuals/JDhydcyl.pdf
   / Help! Damage to cylinder #10
You have to get a cylinder that is the same exact diameter and length, or you will have proportioning problems for sure. Depending on the pin size, you might need to using bushings to make that part of it work. Baileynet.com has those too.
2012 MACK WINCH TRUCK (A53843)
2012 MACK WINCH...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
John Dozer JD650 (A51691)
John Dozer JD650...
2012 ADDCO Arrowboard (A52377)
2012 ADDCO...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
