Help - Cold starting
/ Help - Cold starting #1
gerry100
First winter with a diesel , won't start at 20 deg.
Massey 1010,4wd,306 hours.16Hp diesel, new battery.
Cranks well. I'm following directions from the manual ( 60 sec glow etc).
Will not fire.
I'm not seeing any puffs from the exhaust during cranking so I'm suspecting fuel supply or gelling. Fuel is mostly from summer.
Suggestions on a fuel additive? Any other ideas.
Ran well when I started in 25 deg a few weeks ago, but does not start right up, needed a lot of cranking.
Advice appreciated.
/ Help - Cold starting #2
Sounds a bit 'tired' and if it is not, then checking to see that the glo plugs are working. If ok, then checking to see if there is fuel available through working injectors and fuel pump. If okay, then checking the compression. Sounds like time to get it checked out by a diesel mechanic, and tuned up.
Could be any number of things.
Where are you located? (I read your past posts and see you are in the Albany, NY area). We have days here in Wisconsin in the 30's and 40's (42 now) and would think you could find some where it would start.
Would be helpful for us if you would fill out your bio. Thanks. /forums/images/graemlins/wink.gif
Thanks for getting back.
Started/ran well before it got cold, and with 300hrs I don't think anything should be tired.
I'm In upstate NY ( Near albany).
PLan is to get some fuel additive and maybe a new filter.
Again, cranking speed doesn't seem to be a problem, just can't get a cough or sputter. Previosly before it fored up, I got some blue /white puffs from the stack which suggests soem fuel in the cylinders.
Today no puffs, so I'm guessing the fuel isn'r flowing.
/ Help - Cold starting #4
If you have a propane torch, try preheating the air going into the intake, I have done that on larger diesels and it works quite well.
/ Help - Cold starting #5
Warm weather is coming for you next week. At least above freezing (I see you have 12° F this afternoon - brrrrr).
I have about 300 hours on my diesel, and it cranks and starts always within 2 seconds, never more, and down in the below zero numbers. If you have diesel fuel in there from the summer, then maybe it doesn't have the winter addatives. I usually don't put in but about 3 gal at a time, to be sure the fuel is fresh and 'in season'.
Hope you get it going. If last summers fuel, I'd drain it and put in fresh fuel, if mine. I don't like the 'addatives' that are on the shelves, as I don't trust all that they claim to be on the labels. Just me.
/ Help - Cold starting #6
Suggestions from the North:
Switch fuel from #2 to #1 for winter. If it's not to cold where you live 50/50 might be ok.
I also use Sea Foam fuel additive. It helps keep the injectors clean and prevents the fuel from gelling. (Check with your dealer/ manufacture before you use it so you don't void a warrenty).
I would also have a block heater installed. My tractor sits in an un-heated shed. I plug it in for an hour or so and it will start at 40 below zero. It is better for the tractor to warm it up with a block heater even at 20 above zero.
Just my thoughts. I bet your fuel is gelled up.
/ Help - Cold starting #7
Another possibility is water in the fuel from condensation.
With the wild temperature swings we've had in the northeast (I'm in Quebec), everything in my unheated garage was soaking wet yesterday when it was +50F; it's frozen solid today at 0F! If the fuel tank wan't full then the chances of water condensing inside the tank are pretty good. Doesn't take much...
A diesel additive with antifreeze should bring it back to life, IMO.
Tom.
Maybe a dumb question ( I'm a newby).
Wouldn't the fuel from the gas station puchased a few weeks ago be OK for winter? It's probably 1/3 the new stuff.
/ Help - Cold starting #9
As per Jim ND for the long term.
To get it going throw a tarp over it and put an electric heater under it. After you get it started add the fuel additive so it can mix. It will not mix when cold.
Egon
/ Help - Cold starting #10
A gentle and most brief shot of ether in the air intake works wonders. Gotta be carful though as too much can blow things up. I know the general wisdom is to never use it, and you shouldn't if you are not comfortable doing so. For me though its been a regular item for all of my diesel tractors in cold weather for many years with no problems, but like I say it can be dangerous if too much is used. But then that is also true for many other things.
Unfortunately, no electricity availble in the shed where I keep the tractor.
Right now it looks like, i'll try to strt when the waether gets warmer and put in the fuel additive then
/ Help - Cold starting #12
</font><font color="blue" class="small">( Wouldn't the fuel from the gas station puchased a few weeks ago be OK for winter? It's probably 1/3 the new stuff. )</font>
If you are near Albany NY, then what you bought at the gas station recently is definitely okay for winter.
If you dip something like a clean dowel into the fuel tank, you'll see whether the diesel in there is gelling or not.
Tom.
/ Help - Cold starting #13
gerry100
I would think that fuel would be 'good enough' at the temps you are talking. Only a few degrees below freezing.
I think you have other problems, beyond the fuel. But that remains to be seen.
Good luck.
/ Help - Cold starting #14
Gerry100:
If the fuel is gelled, whch means it has turned to a waxy state, it will have to be warmed. The best way to do that is to pull the tractor if possible into a heated building.
Be careful using the plastic tarps that can be purchased at hardware stores etc. They will burst into flames faster than a blink on an eye from just one spark. I know from personal experience. /forums/images/graemlins/blush.gif
It is possible that even with #1 fuel in the tank that the glow plugs will not start the engine. I have tried many times to start my tractor without plugging it in and it would not start. I would then plug it in for half an hour and it would start right up. In that case I think the oil is to thick to allow the engine to turn over fast enough to start. If by chance the wrong viscosity oil has been used in the crankcase that could be the problem. The solution is to some how get the tractor warmed up with out setting it on fire by accident.
I hate it when things like this happen. /forums/images/graemlins/mad.gif
/ Help - Cold starting #15
hi there. try replacing the fuel filter. i have read where if there is the slightest water in it, it will definitely restrict fuel flow. one of the best things you can do is replace the fuel filter once a year right before it gets cold, right around oct/nov. the fuel may be fine, but if it can't get to the engine, it can't fire up. just my 2 cents worth. hope you can get it going.
/ Help - Cold starting #16
"A gentle and most brief shot of ether in the air intake works wonders. "
Not a good idea if the tractor has a heater element in the intake.
Since Gerry mentioned:
"Fuel is mostly from summer."
Odds are the fuel has gelled. I'd add an additive, but that won't help the fuel in the lines. Right now, he has to warm that engine...hot water would be good, if he can do that. He could light off a small fire outside his shed and melt snow (if any).
I'll wager Gerry won't make this mistake again!
/ Help - Cold starting #17
Since you are not getting any kind of smoke out of the exhaust then you are not getting any fuel to the combustion chamber.
Check filter, fuel shut off (if applies) and clogged tank.
You can also try loosening up a injector line (while cranking engine)at the injector to see if you really are not getting any fuel to injectors.
/ Help - Cold starting #18
You could go to a 5W40 engine oil or maybe 5w30 get the first number down from 15w40, it will not be like molasses
on cold days, the engine will crank faster and build up compression quicker, you could give it very small whiff of ether but this can be big time trouble if you are not carefull with the amount of spray, if it is stored outside put a tarp over the engine when shut down for the night, it will help lower the windchill on the block...this assumes the fuel is not all gelled up...
/ Help - Cold starting #19
At +20 degrees the fuel should not be gelled, even if it is summer fuel. However, if there is water in the fuel filter, it will definitely freeze and cause exactly the same problem--no fuel flow.
Has the fuel filter been changed lately? If not, at 300 hours, you will be doing yourself a favor by changing it. It could very well have enough water in it to cause the problem.
/ Help - Cold starting #20
If it is above 20 degrees, 9 times out of 10 it is a plugged fuel filter. Water, dirt, & etc. This fall we have had a shortage of diesel, & have had _very_ poor fuel quality, folks all across the country are having big issues with bad fuel, clogged filters.
Some newer designs are self-priming, most still need to be primed when you change the filter - or run out of fuel. Read that portion of your manual..... Tractor will _not_ start when you intoroduce air into the line until you bleed the lines......
If it is below 20, it is possible your fuel is gelled. There are products like Power Service brand that will let you use summer (#2) fuel. Or you can use #1 fuel. At your point, if you have mostly #2 in the system, you can buy another product, such as 911 by Power Service, that will soak itself in towards your fuel filter & through the lines. It does work, but is not a miricale worker for all situations. I would put the anti-gel stuff in now, let it work, and try to start it the following day. Changing the filter out also helps a lot for a gelled up system.
It's a toss-up what your problem is, gelled fuel or clogged filter, but the solution is to put in an anti-gel & change the filter, either way...... Dirty watery fuel is a serious problem this year.
I run the farm diesel's down to 5 or 10 below in this climate. This fall I goofed, put in an anti-gell anti-freeze, tractor died on me 10 minutes later. Replaced the filter, ran another 10 minutes & died. Turned out I got the wrong container of anti-freeze, got a gasoline only product, it lowered the flash point of the fuel and broke out the wax so it clumped on the filter. Drained the tank, filled with fresh #2 and Power Service, bled the lines (for the 3rd time, in a 15 degree shed...) and has run since.
It's easy toget messed up fuel.
Other remote possibilities are: Your tank is empty, your fuel shut-off selinoid isn't working, your glow plugs aren't working.
--->Paul
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
32in. Tilt Grading Bucket Mini Excavator Attachment (A59228)
32in. Tilt Grading...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
