HELP - Calcium chloride rusting!!!
/ HELP - Calcium chloride rusting!!! #11
Sounds like RimGuard is the perfect answer. Non-toxic for animals AND biodegradable AND a density on par with CaCl. Everybody wins /forums/images/graemlins/smile.gif
/ HELP - Calcium chloride rusting!!! #12
<font color="blue">Looks like it hads starting from the CaLCium filler. What now? Sandblast and repaint? </font>
Morning widmn, guess I will be only the second person to actually answer the question you asked. /forums/images/graemlins/tongue.gif /forums/images/graemlins/cool.gif
Since you mentioned 'light rust' sandblasting seems like overkill. Wouldn't sanding to remove the rust followed by a good anti-rust primer then paint suffice?
/ HELP - Calcium chloride rusting!!! #13
There are supposed to be tubes put in the tire before it is loaded. Sounds like it wasnt' done in this case.
/ HELP - Calcium chloride rusting!!! #15
The need for a ballasted tractor isn't exclusive to tillage work. I live in hilly country. We need a heavy tractor to move hay wagons. Traction equals safety and control.... Just for giggles, try backing a loaded hay rack in a barn while the ground's wet, with an under-weighted tractor. /forums/images/graemlins/tongue.gif
This issue is the #1 topic of discussion on darn near every "tractor website" I've ever visited. /forums/images/graemlins/crazy.gif
/ HELP - Calcium chloride rusting!!! #16
Hook a heavy tractor the hayrack and it will just sink. Thats why all our tractors are front wheel assist.
/ HELP - Calcium chloride rusting!!! #17
Maybe you didn't read my post and surely not my bio, but I grow forage so no animals. I'd never use antifreeze in tires, nor beet pulp, nor CaCl nor windshield washer fluid. Nothing but compressed air.
Loaded tires in an ag application are for tillage and that's even getting old school. In my business, the lighter the footprint of the prime mover, the less impact on the forage plant.
If I need some counterweight for the FEL and most times I don't, I'd just put on the rear spear and hang a round bale out back........edible counterweight. /forums/images/graemlins/grin.gif
/ HELP - Calcium chloride rusting!!! #18
The only thing I'd add to Daryl's post about filling tires without thinking is getting to be a thing of the past.
Farmers are learning proper ballasting and you see more weight bars and front 3 point hitches loaded with weight matching what they have on the back to get their ratio right.
/ HELP - Calcium chloride rusting!!! #19
/ HELP - Calcium chloride rusting!!! #20
I would take that junk out of your tires and make up for the loss with wheel weights or additional cast iron added to the 3-point. If and when you need less weight it's a LOT easier to shed pounds than with filled tires.
2025 AGT Industrial MX-MRT14 (A60463)
2025 AGT...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2023 John Deere Z994R (A60463)
2023 John Deere...
2012 ISUZU NPR FLAT BED 4X2 TRUCK WITH PUMP SYSTEM (A59906)
2012 ISUZU NPR...
