HELP - Calcium chloride rusting!!!
/ HELP - Calcium chloride rusting!!! #31
The foam is superb for puncture protection.. and adds a bit of weight.. but not like water+.. also you'll have to seel some children to the slave market to pay for foam filling if you have big tires! /forums/images/graemlins/wink.gif
Seriuusly though.. if you are concerned about rust.. fill your tires with an eco friendly antifreeze and water combo.. the more AF the heavier it gets.. and it is corosion 'resistant'.. also.. use a tube!
Soundguy
/ HELP - Calcium chloride rusting!!! #32
</font><font color="blue" class="small">( R4s at my request. I figured they would be better for mowing than the Ags )</font>
I don't have much of an ag tire problem when mowing.. but then I mow a pasture.. not a lawn. I've found a narrow tri rib front will print worse than anything.. however.. a quick turn on loose or soft grass/soil WILL eat up some soil with an ag tire.
Loaded tires are great for loaders.. but tougher on grass.
Like everyone is telling you.. that deal with condensation/tubes/cacl.. etc from your dealer.. well... lotsa tractor guys are telling you they run loaded tubes vs loaded bare rims.. there IS a reason for that.... /forums/images/graemlins/smirk.gif
To the guy with the beet juice spill. I understand that high sugar content will kill same as salt content. I've noticed that gras dies around a cattle molassis lick tub same as around a salt block..??
Soundguy
/ HELP - Calcium chloride rusting!!! #33
"He says the only problems he's seen with Calcium-filled tires have been caused by using tubes. Water condenses between the tube & rim and that's what causes rust."
The condensation/rusting he is referring to has nothing to do with calcium chloride, but water leaking past a leaking rim/bead and being trapped by the tube, whereas a tubeless tire would just go flat and be repaired.
2020 FORD F-600 SERVICE TRUCK (A60736)
2020 FORD F-600...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2017 PETERBILT PB337 HYDRA-TAIL FLATBED TRUCK (A59823)
2017 PETERBILT...
2022 Ram 2500 (A55973)
207279 (A52708)
207279 (A52708)
