Backhoe Help! BX23 Backhoe won't come off, already used search
   / Help! BX23 Backhoe won't come off, already used search #11
Just the other day, I had a similar episode with my backhoe... only in reverse. After sitting for two months, backed up to the hoe and couldn't get it to couple to the tractor. Found the clamp blocks frozen in the open position. Penetrating lube and a hammer got them to start moving. Removed the end plates and with large slip-joint pliers, managed to work the clamp blocks off the pins. Sanded the corrosion off the pins and clamp blocks and reassembled with a coating of grease.
After eight years storing the tractor outside, I guess it was my time. From the looks of the parts, I don't think there was ever any lubricant applied to these parts.
Pull-Behind Batwing Rotary Brush Cutter Attachment (A59228)
Pull-Behind...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
PumpJack Brand Pump Jack (A56436)
PumpJack Brand...
2003 International 9200I (A53317)
2003 International...
2018 John Deere Z997R (A53317)
2018 John Deere...
