Help! Bobcat 225 can't even pickup a 1500lb round bale with 3 point
   / Help! Bobcat 225 can't even pickup a 1500lb round bale with 3 point #41
When I have some time I will go back through some of my old farm equipment links.
This might make for a good build it project - simple enough to pivot a spear on a solid axle. But in my case I don't weld and have zero fabrication ability.
on edit
It was something like this but had dolly/swivel wheels just below the lower link arms and used a hydraulic cylinder to pivot.
Fred Cain Tractor 3 Point Hitch Scissor High Lift Hay Lift #3F uses #3F Bale Spear
Time to get a hydraulic pressure gauge. Assuming you have quick connects on your machine it should be pretty simple to hook up and see what kind of pressure your machine is producing.
Can someone tell me what PSI gauge to get, to check hydraulics.
Thanks!
   / Help! Bobcat 225 can't even pickup a 1500lb round bale with 3 point #43
Kens bolt on hooks sells them
   / Help! Bobcat 225 can't even pickup a 1500lb round bale with 3 point #44
  • 2018-01-11-020422 bobcat.pdf
  • 2018-01-11-020550 bobcat.pdf
  • 2018-01-11-020726 bobcat.pdf
  • 2018-01-11-020829 bobcat.pdf
  • 2018-01-11-020943 bobcat.pdf
  • 2018-01-11-021033 bobcat.pdf
   / Help! Bobcat 225 can't even pickup a 1500lb round bale with 3 point #46
I got mine from kens bolt on. Works great.
2016 International WorkStar 7400 Cylinder Pallet Flatbed Truck (A55852)
2016 International...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55314)
Koyker Loader...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
Kubota M5-111 (A53317)
