Help! Bobcat 225 can't even pickup a 1500lb round bale with 3 point
   / Help! Bobcat 225 can't even pickup a 1500lb round bale with 3 point #41
When I have some time I will go back through some of my old farm equipment links.
This might make for a good build it project - simple enough to pivot a spear on a solid axle. But in my case I don't weld and have zero fabrication ability.
on edit
It was something like this but had dolly/swivel wheels just below the lower link arms and used a hydraulic cylinder to pivot.
Fred Cain Tractor 3 Point Hitch Scissor High Lift Hay Lift #3F uses #3F Bale Spear
Time to get a hydraulic pressure gauge. Assuming you have quick connects on your machine it should be pretty simple to hook up and see what kind of pressure your machine is producing.
Can someone tell me what PSI gauge to get, to check hydraulics.
Thanks!
   / Help! Bobcat 225 can't even pickup a 1500lb round bale with 3 point #43
Kens bolt on hooks sells them
   / Help! Bobcat 225 can't even pickup a 1500lb round bale with 3 point #44
  • 2018-01-11-020422 bobcat.pdf
  • 2018-01-11-020550 bobcat.pdf
  • 2018-01-11-020726 bobcat.pdf
  • 2018-01-11-020829 bobcat.pdf
  • 2018-01-11-020943 bobcat.pdf
  • 2018-01-11-021033 bobcat.pdf
   / Help! Bobcat 225 can't even pickup a 1500lb round bale with 3 point #46
I got mine from kens bolt on. Works great.
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55852)
2004 Pierce Tilt...
STEEL SLINGS (A54757)
2008 Toyota Camry LE Sedan (A55853)
2008 Toyota Camry...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
2019 Bobcat 3400 4x4 Utility Cart (A55851)
2019 Bobcat 3400...
